Autodesk Inventor Customization
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Ilogic View Reps on dwg
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HI
I am after help on some ilogic code ,I have had some code done to isolate selected parts in a assembly file that has a specific custom property filled in i.e. : DESC2.It then creates view reps and locks down giving the rep name the same name as part.
What I am after if any one can help is some code that will place these isolated view reps as views on my dwg that the assembly resides in.With the functionality of picking face to show plan view of parts.
Any thoughts would be appreciated.
Dave
Re: Ilogic View Reps on dwg
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If I understand correctly, you want to place the drawing views from one assembly in specific view reps (or even specific LOD etc) like UI does (see attachment). If yes, you could use Advanced API of ilogic to access Inventor API. DrawingViews.AddBaseView allows you to specify additional or advanced options:
Name
Value Type
WeldmentFeatureGroup
Weldment
SheetMetalFoldedModel
Boolean
Sheet Metal
String
Part, Assembly
DesignViewAssociative
Boolean
Part, Assembly
String
Assembly
MemberName
String
Part, Assembly
PresentationView
String
Presentation
PresentationViewAssociative
Boolean
Presentation
Following is a demo code I converted from the sample in the help reference of Inventor API:
' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument 'Set a reference to the active sheet. Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet ' Create a new NameValueMap object Dim oBaseViewOptions As NameValueMap oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Set the representations to use when creating the base view. 'Call oBaseViewOptions.Add("PositionalRepresentation", "MyPositionalRep") Call oBaseViewOptions.Add("DesignViewRepresentation", "Default") 'Call oBaseViewOptions.Add("DesignViewAssociative", True) ' Open the model document (corresponding to the "MyLODRep" representation). Dim strFullDocumentName As String strFullDocumentName = ThisApplication.FileManager.GetFullDocumentName("c :\temp\reps.iam", "Master") Dim oModel As Document oModel = ThisApplication.Documents.Open(strFullDocumentName , False) ' Create the placement point object. Dim oPoint As Point2d oPoint = ThisApplication.TransientGeometry.CreatePoint2d(25 , 25) ' Create a base view. Dim oBaseView As DrawingView oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 2, _ kIsoTopLeftViewOrientation, kHiddenLineRemovedDrawingViewStyle, _ , , oBaseViewOptions)
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
