• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Active Member
    Accepted Solution
    Ilogic : Perform a CODE using iproperty information
    161 Views, 3 Replies
    09-17-2012 05:39 AM
    Hi
    I want to use Ilogic to construct a code part name.
    My question is perform a code of about 12 characters. For example the parameter "Lenght" is 600mm but in the expressione result It must be "000000000600" (a string of 12 characters)
    Thank you in advance
    Fabio
    Please use plain text.
    Valued Mentor
    Re: Ilogic : Perform a CODE using iproperty information
    09-18-2012 07:29 AM in reply to: fabio.chiesa
    I'm kinda bored waiting for a reply to my own thread, hence spamming what might not be replies to peoples questions, anyway:
    Private Sub TestFormat()
        Dim length As Integer
        length = 600
        Dim code As String
        code = Format(600, "000000000000")
    End Sub
    Inventor Professional 2012 SP1 (25 seats with subscription)
    Windows 7 64 bit
    Lenovo D20, 12 GB RAM, Intel Xeon X5687 3.6 GHz, SSD
    Quadro 4000, driver 8.17.12.9573, dual monitors
    SpacePilot, driver version 6.15.3 Firmware 3.12
    Active Member
    09-25-2012 09:18 AM in reply to: JohanLarsson
    Thank you very much and sorry if I read your response delay
    Tomorrow I'll test it
    Regards
    Fabio
    Active Member
    09-27-2012 03:45 AM in reply to: JohanLarsson
    Yes it work so fine but if my "lengt" is not a number.
    For ex: "A600" and i wont to convert it in "00000000A600"
    Regards
    Fabio
