IPART CHANGE ROW
IPART CHANGE ROW
dcmorgan
IPART CHANGE ROW
dcmorgan
Can Somebody please help me with my code. I am trying to switch component rows within my assembly file but can't seem to do so. All of the files are generated, yet and still I am not able to change component rows based on user parameters. Please help. Files are attached.
My code is as follow in Ilogic
MultiValue.Setlist("Material", "1", "2")
If Material = "2"
iPart.ChangeRow("RING", "RING-03:1")
End If
Inventor version?
xiaoyan.qi
Hi
 I tried to open your attached assembly files, there are unresolve files. so i created a simple assmbly, see attached for details(you need to open the iPart file and generate the files firstly)
in your case, we should use the iLogic Statement ChangeRow (use parent filename): iPart.ChangeRow("iParentFileName:1", "rowName")
 for your statement : iPart.ChangeRow("RING", "RING-03:1")
"RING" should be "RING:1", it stands for the iPart file
"RING-03:1" should be "RING-03", it stands for the row name of the iPart
let me know if it works
Mick
