Autodesk Inventor Customization
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How to test for EVEN or ODD variable values with iLogic 2012?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm attempting to build a sheet metal panel in a rectangular pattern both vertically and horizontally. All holes in pattern are to be the same size. The other criteria that the pattern MUST follow is that the hole pattern itself, whether square or rectangular MUST BE CENTERED on the sheet metal face.
Using an iLogic Form, I am able to drive the dimensions for the sheet itself, the hole diameter, the number of rows and the number of columns. I am also able to input offsets both/either vertically or horizontally. When either or both the Number of Rows or the Number of Columns is odd, one (1) hole centrally placed on the sheet metal face allows for my design intent to work properly. When the hole pattern requires either an even number of Rows or Columns, an offset is needed. Through some experimentation, I've been able to figure out the amount of displacement required to center this type of hole pattern.
What I'm in need of is code to test that either the Number_of_Rows value is even or odd and Number_of_Columns is either even or odd. After testing for even or odd iLogic needs to update the hole location both horizontally and/or vertically as needed. Instructions on how to update variable with iLogic are also needed. I'm a newbie! ![]()
Code would be similar to the following:
Test Number_of_Rows for "oddness"
If Number of Rows is odd then
oHOFFSET = 0
ELSE oHOFFSET = 3
Parameter ("Horizontal_Offset") = 3
END IF
Any tips, suggestions or errata on testing a value for being even or odd would be greatly appreciated!
Inventor 2012 Certified Associate
AutoCAD 2012 Certified Associate
Product Design Suite Ultimate 2012 & 2013
Other than THAT, Mrs. Lincoln, how was the play??
Illinois: Where we send more Govenors to prison, than on to retirement!
Re: How to test for EVEN or ODD variable values with iLogic 2012?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The modulo operator is what you're looking for (Mod in iLogic or % pretty much everywhere else). It returns the remainder after a division.
If NumberOfRows Mod 2 = 0 Then //Do even things Else //Do odd things End If
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If NumberOfRows Mod 2 = 0 Then //Do even things Else //Do odd things End IfSince I wish to test Odd first, I should use the following code:
If Number_of_Rows Mod 2 = 1 Then
// Do odd things
ELSE
// Do even things
End If
Would that be correct?
Thank you for your assistance. It is greatly appreciated!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks a million! I've just finished cigarette pack #3 trying to figure this stuff out.
