How to delete ilogic forms using .net
Message 1 of 12
Hi all,
Could someone please tell me how to delete iLogic forms from Inventor 2013 parts/assembly using VB.net 2010?
I am able to delete all the rule using "Activated_iLogic.DeleteAllRules(PartDoc)" but "Activated_iLogic.DeleteAllForms(PartDoc)" or "Activated_iLogic.DeleteForm(PartDoc, FormName)" does not give me the result I was expecting and Google is not showing any result related to this.
Many thanks in advance.
JJ
Replies (11)
Message 2 of 12
The forms are stored in the document's attributesets.  If you delete the attributeset/attribute, the form is gone.
Message 3 of 12
Hi Farren,
thanks for the suggestion. I can't get it to work but that is because of my lack of understanding the API & .net skills.
Message 4 of 12
xiaodong_liang
Autodesk Support
Autodesk Support
Message 5 of 12
Hi Xiaodong, thanks for your reply.
I was able to delete rules and I tought that if I wanted to delete forms I needed to use the iLogic statements so that's how I came up with the 2 methods.
I have started with vb.net a couple of weeks ago and still struggling understanding the API and how to communicate with Inventor when I want something done. Replacing parts or subassemblies in an assembly took me a day to get that working. I am on a trail and error mode to get things done.
Message 6 of 12
xiaodong_liang
Autodesk Support
Autodesk Support
Sorry, I still have no idea how to delete the iLogic form by code. I doubt this may be a requirement which has not been exposed.
Message 7 of 12
BWMcDowell
Was looking for the same thing and found this
Hope i helps
https://www.cadlinecommunity.co.uk/hc/en-us/articles/202020531-Inventor-2015-iLogic-Delete-All-iLogi... by LukeDavenport
Message 8 of 12
dba78
I see, this is an old post 🙂
in .net you need a reference to Autodesk.ilogic.core.dll
then you can use:
Imports ilc = Autodesk.iLogic.Core
public class myIlogic
    Public Shared Sub DeleteForms(doc As Document, optional FormName a string =Nothing)
        Dim uiatts As New ilc.UiBuilderStorage.UiAttributeStorage(doc)
        For Each name In uiatts.FormNames
            Dim fsp = uiatts.LoadFormSpecification(name)
            if FormName isnot nothing
                if FormName.Equals(name) Then
                    uiatts.DeleteFormSpecification(name)
                end if
            else
            End if
        Next
    End Sub
end class
BR,
Daniel
Daniel Balogh
Application Engineer/Developer
cad-balogh.com
Message 9 of 12
hkempeneers
Hi Daniel,
I see this is a very old post...🙈
Thank you for the code.
But how can I manipulate this code for use in iLogic?
In version 2019 this code fails. (see picture)
We really need code to delete forms from within an Inventor model.
Message 10 of 12
dba78
Hi, in an iLogic rule the core would look something like this
This code should delete all forms in the current document.
AddReference "Autodesk.iLogic.Core.dll"
AddReference "Autodesk.iLogic.UiBuilderCore.dll"
Imports ilc= Autodesk.iLogic.Core
Dim doc = ThisApplication.ActiveDocument
Next
This throws me an error on inventor 2020.3.1 stating there was  problem with the different Versions of the referenced Assemblies.... However, you may be lucky and there is not version-interference in the 2019-assemblies.
I couldn't find any option to turn off the version restriction in iLogic (not sure this constellation would even work in a .net-Addin).
Anyway,  the code should work, if the assemblies aren't mixed up (by Autodesk)
Alternatively you may check the Attributes of the Document (since iLogic stores all its information in a document-Attributes) and delete them.... This is a real brute-force attempt but might work for your scenario:
Dim Attset As Inventor.AttributeSet
Dim doc As Inventor.Document
For Each Attset In doc.AttributeSets
	If Attset.Name Like "iLogicInternalUi*" Then
		Attset.Delete
Next
as a side node, the Forms are cached, so they will still be available until the iLogic-Window isn't closed and reopened.
HTH,
Daniel
Daniel Balogh
cad-balogh.com
Message 11 of 12
hkempeneers
Hi Daniel,
Many thanks for this solutions!
It works for us.
You wrote "This is a real brute-force attempt.."
Sometimes we need brute force to make life more pleasant. 😉
Message 12 of 12
dba78
So true...! 😁
Daniel Balogh
cad-balogh.com
