• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    How to create a excel file using ilogic? Thanks
    397 Views, 5 Replies
    06-27-2012 09:56 AM
    Please use plain text.
    Curtis_Waguespack
    Re: How to create a excel file using ilogic? Thanks
    06-27-2012 10:34 AM in reply to: MtigaM
    Hi MtigaM,
    Here is an iLogic example.
    I hope this helps.
    Curtis
    'define the file to create/open
    myXLS_File = "C:\Temp\Best_Excel_File_Ever.xls"
    ‘get the Inventor user name from the Inventor Options
    myName= ThisApplication.GeneralOptions.UserName
    'define Excel Application object
    excelApp = CreateObject("Excel.Application")
    'set Excel to run visibly, change to false if you want to run it invisibly
    excelApp.Visible = True
    'suppress prompts (such as the compatibility checker)
    excelApp.DisplayAlerts = false
    'check for existing file
    If Dir(myXLS_File) <> "" Then
    'workbook exists, open it
    excelWorkbook = excelApp.Workbooks.Open(myXLS_File)
    ExcelSheet = ExcelWorkbook.Worksheets(1)
    Else
    'workbook does NOT exist, so create a new one
    excelWorkbook = excelApp.Workbooks.Add
    End if
    'Insert data into Excel.
    With excelApp
        .Range("A1").Select
        .ActiveCell.FormulaR1C1 = "Hello, " & myName
    End With
    'set all of the columns to autofit
    excelApp.Columns.AutoFit
    'save the file
    excelWorkbook.SaveAs (myXLS_File)
    ''close the workbook and the Excel Application
    ''uncomment if you want to close the xls file at the end
    'excelWorkbook.Close
    'excelApp.Quit
    'excelApp = Nothing
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    06-27-2012 10:45 AM in reply to: Curtis_Waguespack
    Thanks alot, this is what i am looking for!
    06-27-2012 10:55 AM in reply to: MtigaM
    Is it possible to open a template excel file somewhere and then save it as a new excel in another place?
    Curtis_Waguespack
    06-27-2012 11:54 AM in reply to: MtigaM
    Hi MtigaM,
    To specify the template to use you can use this example.
    I hope this helps.
    Curtis
    Else
    'create a new spreadsheet from template
    excelWorkbook = excelApp.Workbooks.Add (Template: = "C:\Temp\Best_Excel_Template_Ever.xlt")
    End if
    With excelApp
    	.Range("A1").Select
    End With
    'save the file
    'excelApp.Quit
    'excelApp = Nothing
    06-27-2012 12:11 PM in reply to: Curtis_Waguespack
    Thank you very much!
