How do you open a .htm file within an Inventor VBA prog from a button.
Hi - a real easy question for someone who knows the answer.
How do you open a .htm file and set it as the focused window within an Inventor VBA prog from a button on a userform?
I just want to add a quick help page for a program I've cobbled together.
Thanks in advance for any help anyone can give.
Nik
pball
This is what I was given for opening files before. It will just open the file using the default program on the computer.
        Dim myShell As Object
        Set myShell = CreateObject("WScript.Shell")
        myShell.Run quote(FilePath)
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
Thankyou - that is exactly what I was after!
Cheers
Nik
