GetReferenceKey
GetReferenceKey
GetReferenceKey
Have any body idea about the GetReferenceKey method of classes. I got a sample code from some where and tried to get the key for each face of a part but what i found that it is the same for most faces and only different for one or two face. Can any body help in this matter.
Manoj
Manoj,
The keys are unique for faces/edges/surface bodies
etc., and I see no problem in getting these keys. My best guess is that your
method
of comparing the keys is incorrect.
As a test trying highlighting the faces for which
you have obtained the keys. And then bind the key back to the face and then
highlight again.
With this you would notice that in both cases it is
refering to the same key.
Sub testRefKeys()
    Dim oDoc As
PartDocument
    Dim nKeyCont As Long
    Set oDoc =
ThisApplication.ActiveDocument
        Dim oCompDef As
PartComponentDefinition
        Set
oCompDef =
oDoc.ComponentDefinition
        ' Get the key
context
        ' Calling this method is a
must
        nKeyCont =
oDoc.ReferenceKeyManager.CreateKeyContext
        Dim oFace As
Face
        Set oFace =
oCompDef.SurfaceBodies(0).Faces(1)
        oDoc.HighlightSets.Add.AddItem
oFace
        'Get the reference Key from
face
        Dim oFaceRef() As
Byte
        Call
oFace.GetReferenceKey(oFaceRef,
nKeyCont)
        'Now get the face from the
Reference Key
        Dim oFacenew As
Face
        Set oFacenew =
oDoc.ReferenceKeyManager.BindKeyToObject(oFaceRef,
nKeyCont)
oFacenew
End Sub
Cheers
Thilak
Manoj
