Files with external Link
GeorgK
Advisor Advisor
GeorgK
Hello together,
is it possible to show all files from a folder with external links in a listbox? Is it possible to check if the link is OK?
Thank you very much
Georg
adam.nagy
Autodesk Support
Autodesk Support
Hi Georg,
You can check what other files a document is referencing through the DocumentDescriptorsEnumerator and ReferencedOLEFileDescriptors collection.
You could also use Apprentice Server Component so no need to start inventor. Here is a sample using Apprentice: http://adndevblog.typepad.com/manufacturing/2012/11/using-inventor-properties-from-apprentice-server...
Cheers,
Adam Nagy
Autodesk Platform Services
