• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    New Member
    Export drw BOM (parts list) to excel
    335 Views, 2 Replies
    04-27-2012 06:31 AM
    Hi.
    I have a drawing with multible sheets (spool drawings) all with there owne parts list and I need to export them all to excel. This takes a long time when you have 100 sheets. So my question is how can I doo this, how should the code look like?
    Please use plain text.
    Active Contributor
    achmidt
    Re: Export drw BOM (parts list) to excel
    04-27-2012 08:06 AM in reply to: ges87
    Try this code below as a start, you may need to create a loop for sheets.
    'Export PartsList
    path_and_name = ThisDoc.PathAndFileName(False) ' without extension
    Dim oDoc As Inventor.DrawingDocument
    oDoc = ThisDoc.Document
    Dim oSheet As Inventor.Sheet
    'oSheet = oDoc.Sheets(1) ' first sheet
    oSheet = oDoc.Sheets("Sheet:1") ' sheet by name
    'skip error in case no parts lists exist
    On Error Resume Next
    oPartslist1 = oSheet.PartsLists(1)
    oPartslist2 = oSheet.PartsLists(2)
    Dim oCol As Long
    For oCol = 1 To oPartsList1.PartsListColumns.Count
    'find the parts list that contains the LibRef column
    If oPartslist1.PartsListColumns.Item(oCol).Title  = "LibRef" Then
    ' export the Partslist to Excel.
    oPartslist1.Export(path_and_name & ".xls",PartsListFileFormatEnum.kMicrosoftExcel)
    Else
    oPartslist2.Export(path_and_name & ".xls",PartsListFileFormatEnum.kMicrosoftExcel)
    End If
    Next
    New Member
    05-01-2012 11:13 PM in reply to: achmidt
    hi. thanks for the respons. But i cant get this to work. It does not create the file. I have tried many different codes but they never manage to create the excel file.
