Autodesk Inventor Customization
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Edit AutoCAD attributes
- Highlight
- Email to a Friend
We have a program to update our titleblocks, the following code has worked without problems in Inventor 2010.
But in Inventor 2012, it doesn't work every time. When I insert the titleblock for the first time I can fill the attributes,
but when I want to update the titleblock, I see no change, although it has changed the values, which I can see if I manually do an edit attributes (see screenshot).
Any ideas?
Michael
Public Shared Function SaveAutocadAttributes(ByVal intDocID As Integer, ByRef invApp As Inventor.Application) As Boolean
Dim ht As Hashtable = AcadAttributesMapping(intDocID, invApp)
Dim i As Integer
Dim invDoc As DrawingDocument
Dim acadDoc As AcadDatabase
Dim objBlock As AcadBlock = Nothing
Dim objAcadEntity As AcadEntity = Nothing
Dim objAcadBlockReference As AcadBlockReference = Nothing
Dim obj() As Object = Nothing
Dim objAcadObject As AcadObject = Nothing
invDoc = invApp.ActiveDocument
acadDoc = invDoc.ContainingDWGDocument
For Each objBlock In acadDoc.Blocks
For Each objAcadEntity In objBlock
If objAcadEntity.ObjectName.ToLower = "AcDbBlockReference".ToLower Then
objAcadBlockReference = CType(objAcadEntity, AcadBlockReference)
If objAcadBlockReference.HasAttributes Then
Select Case objAcadBlockReference.Name
Case "A0", "A1", "A2", "A3", "A3D", "A4", "P0", "P1", "P2", "P3", "P4"
obj = DirectCast(objAcadBlockReference.GetAttributes, Object())
For i = LBound(obj) To UBound(obj)
If ht.ContainsKey(obj(i).TagString) = True Then
obj(i).TextString = ht.Item(obj(i).TagString)
End If
Next i
End Select
End If
End If
Next
Next
invDoc.Update()
End Function
Re: Edit AutoCAD attributes
- Highlight
- Email to a Friend
Hey Michael,
Did you ever get this to work?
What namespace does AcadAttributesMapping belong to?
Thank you
- Highlight
- Email to a Friend
The following code code works for me.
Public Shared Sub SaveAttributes(ByVal strFieldVaule() As String, ByVal strFieldName() As String, ByRef invApp As Inventor.Application)
Dim myBlockRef As AcadBlockReference
Dim i As Short
Dim h As Short
Dim myAttributes As Object
For Each Entity In acadDoc.PaperSpace
If TypeOf Entity Is AcadBlockReference Then
myBlockRef = Entity
Select Case myBlockRef.Name
Case "A0", "A1", "A2", "A3", "A4", "P0", "P1", "P2", "P3", "P4"
myAttributes = Entity.GetAttributes
For i = LBound(myAttributes) To UBound(myAttributes)
For h = LBound(strFieldName) To UBound(strFieldName)
If strFieldName(h) = myAttributes(i).TagString Then
myAttributes(i).TextString = strFieldVaule(h)
End If
Next
Next i
End Select
End If
Next
invDoc.Update()
End Sub
AcadAttributesMapping was just a function that i made to put attribute values to a Hashtable.
- Highlight
- Email to a Friend
What a legend! Thank you!
- Highlight
- Email to a Friend
I am trying to generate some code to read an Autocad created titleblock with attributes that is in a Inventor 2013 .dwg using Visual Studio Express 2010. However, I have three references "not defined" when starting with the code above.
I have referenced the Inventor's interop library, am I missing another reference? Please see attached screenshot..
AcadBlockReference, DrawingDocument, AcadDatabase are the ones missing.
Dave
- Highlight
- Email to a Friend
You have to reference
Autodesk.AutoCAD.Interop
and
Autodesk.AutoCAD.Interop.Common
- Highlight
- Email to a Friend
Thank you for replying Michael but oddly enough the reference is not defined after adding in autodesk.AutoCAD.Interop and Autodesk.AutoCAD.Interop.Common. Screen shot below.
Using Visual Studio 2010 express.
Dave
- Highlight
- Email to a Friend
You need to put the imports namespace names in the code as well.
Imports Autodesk.AutoCAD.Interop.Common
- Highlight
- Email to a Friend
