• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Employee
    Re: Drawing Automation with VBA
    04-24-2011 08:49 PM in reply to: nttoan8187
    You can use AIGDT font to the FormattedText to show symbols:
    <StyleOverride Font='AIGDT' Bold='False'>n</StyleOverride>
    Rocky Zhang
    Inventor API
    Manufacturing Solutions
    Please use plain text.
    Valued Contributor
    nttoan8187
    04-24-2011 09:44 PM in reply to: yuhanzhang
    Amazing!
    Could you please give me the materials for some special symbol in Format Text? I cannot find out where I can read them.
    For instance: DimensionValue, SectionViewName, etc........
    I got a problem in dimension that is I cannot use GeneralDimensions.AddLinear to dimension between a centerline and a line curve
    'oCLine100 is the center line, oLCurve100 is the line curve. Two lines is parallel. oDimPos is the point 2d
    Dim oGI100, oGI101 As GeometryIntent
    Set oGI100 = oSheet.CreateGeometryIntent(oLCurve100)
    Set oGI101 = oSheet.CreateGeometryIntent(oCLine100)
    Dim oLDim100 As LinearGeneralDimension
    Set oLDim100 = oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oDimPos100, oGI100, oGI101, kDiametricDimensionType)
    Please help me to figure out what goes wrong in the code????
    This GeneralDimensions.AddLinear() is really terrible. It make my Inventor crash down more than 15 time per day........... although I use "On Error Resume Next" before the code line or not.
    Please mark this answer as Problem Solved if it solves your question.
    Toan
    Inventor API
    Valued Contributor
    nttoan8187
    04-25-2011 12:19 AM in reply to: nttoan8187
    Sometimes, the problem shows out like this following figure:
    But sometimes, Inventor crash down like this
    For average 30 minutes for one crash like this. If I use the GeneralDimensions.AddLinear 3 or 4 times, it crash down immediately.
    Autodesk men, please check out, I am tired of crash and reopen Inventor and crash and reopen..................................so annoyed
    If you can find out the solution, please make the hot-fix for it!!!!!!!!!!!
    Toan
    Inventor API
    Employee
    04-25-2011 01:34 AM in reply to: nttoan8187
    In API help, you can search the topic titled "XML Tags for FormattedText" to understand more details about FomattedText.
    Can you attach a data to reproduce the failure for adding the diametric linear dimension?
    Rocky Zhang
    Inventor API
    Valued Contributor
    nttoan8187
    04-25-2011 02:27 AM in reply to: yuhanzhang
    Sorry, but it is the company properties, I don't have the permission to attach.......
    But I really DO NOT understand why.
    First,
    I change the code to dimension for two line segment curves, which is only different in Y position, every else is same.
    Then I create the Center Line by two kStartPoint of two lines, it worked
    This means that these two GeometryIntent are right. Then the AddLinear() not work with these two GeometryIntent
    If I don't create CenterLine AddLinear also didn't work!!!!!!! Run two or three time, Inventor crashs down........
    ---> Unbelievable
    Then, I change to the most simple case. I get two geometry intent that is the StartPoint and EndPoint of a line curve.
    AddLinear didn't work too. What happens??????????
    Do you believe this?????
    In two case, I change the color and weight of curves, and it work well---> this means that the curves is not nothing and they are right!
    So, assuming that I don't understand and I write wrong code?????? Why Inventor crashes??????????? Today, I got more than 20 crashes, it is really irritated.
    I know that this sounds stupid, but it was. Now I will try to make a sample to test and send for you........
    Toan
    Inventor API
    Valued Contributor
    nttoan8187
    04-25-2011 03:05 AM in reply to: nttoan8187
    I just create a simple test, it can work, and the List of Properties/Methods can work also
    In my macro, even I press Ctrl+J, it not work??????
    Or the wrong thing happens because my code is too long???????????????
    About 3000 lines and will be 5000 lines if I can use AddLinear to dimension the drawing..................
    How I can solve this problem???? Please help!!!!
    Toan
    Inventor API
    Employee
    04-25-2011 03:49 AM in reply to: nttoan8187
    If the data is protected, can you create another simple sample  to reproduce the issue which you think is safe to attach? Or you can try to select a line segment curve on a drawing, and then run below VBA code to check if it works:
    Sub CreateLinearDiametricDim()
        Dim oDoc As DrawingDocument
        Set oDoc = ThisApplication.ActiveDocument
        Dim oCurve As DrawingCurve
        Set oCurve = oDoc.SelectSet(1).Parent
        Dim oIntent1 As GeometryIntent, oIntent2 As GeometryIntent
        Set oIntent1 = oDoc.ActiveSheet.CreateGeometryIntent(oCurve, kStartPointIntent)
        Set oIntent2 = oDoc.ActiveSheet.CreateGeometryIntent(oCurve, kEndPointIntent)
        Dim oDim As LinearGeneralDimension
        Dim oPt As Point2d
        Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(12, 12)
        Set oDim = oDoc.ActiveSheet.DrawingDimensions.GeneralDimensions.AddLinear(oPt, oIntent1, oIntent2, kDiametricDimensionType)
    End Sub
    As the issue for display the List of Properties/Methods, can you check if there are two subs which have the same name in the module/class?
    Rocky Zhang
    Inventor API
    Valued Contributor
    nttoan8187
    04-26-2011 02:41 AM in reply to: yuhanzhang
    I just think to new solution that doesn't need to dimension automatic by VBA anymore.
    Maybe in my next project, we will discuss more. Thank you so much!
    I have a question about DrawingView:
    How I can Delete the oBaseView but still exist the oIsoView????
    If we do this manually, we can choose No when a prompt appear and ask us to Delete Projected Views or not
    But I don't see any option in DrawingView.Delete() method.
    Toan
    Inventor API
    Valued Contributor
    nttoan8187
    04-26-2011 07:01 PM in reply to: nttoan8187
    Sorry for me,
    I just try and only the obaseview is deleted; the isoview still be there. It's no need to do anything else, thanks IV for this!
    Toan
    Inventor API
