Document Settings
Document Settings
dbrblg
Document Settings
dbrblg
Does anyone know where I can change the 'Default Parameter Input Display' setting under the Units tab of the Document Settings?  I would like to know the route through the API to programatically change this setting.
I have tried
PartDocument>ComponentDefinitions>Parameters &
PartDocument>UnitsOfMeasure
to no avail....!!
dean.morrison
This one I had to ask autodesk through my support!!
Dim oBOMQty As BOMQuantity
Set oBOMQty = oCompDef.BOMQuantity
oBOMQty.SetBaseQuantity kParameterBOMQuantity, oParam    'This one sets it to mm (need to define oParam!)
oBOMQty.SetBaseQuantity kEachBOMQuantity                            'This one sets it to each
Hope this is what you are after.
Dean.
dbrblg
Thanks very much for asking it is much appreciated, however the parameter I was after is shown more clearly in the attached picture, I hope Smiley Happy
Many thanks
dean.morrison
I meant i asked this of my support a while ago....
Anyways i must have been half asleep this morning, as i didnt read your post correctly!
I am not sure where you find that one via API.
To be honest i had not even noticed that setting at ALL!!
hopefully someone else can answer.
Sorry about that!
Dean
Curtis_W
Hi dbrblg,
I know this is an old post, but I just ran across it and thought that I'd add this in case you're still interested and for anyone who might find this in the future.
Dim oDoc As Inventor.PartDocument
oDoc = ThisApplication.ActiveDocument
Dim oParams As Parameters
oParams = oDoc.ComponentDefinition.Parameters
Dim oModelParams As ModelParameters
 oModelParams = oParams.ModelParameters
If oParams.DisplayParameterAsExpression = True  then
oParams.DisplayParameterAsExpression = False
Else if DisplayParameterAsExpression = False Then
end if
This link might also be of interest:
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-show-equation-instead-of-value/td-p/3294589
I hope this helps.
Curtis
dbrblg
Hi Curtis,
Thanks for the update.  The original project I was working on was canned but I am certain this will be useful in the future.
Thanks for remembering this Smiley Happy
