Divide a segment equally with a range in visual basic
How do you divide a segment equally with a range in visual basic?
example-
length is 144 in
range- 7.5 - 9in
answer- (18) at (range 8 in)
like to know how to do this in Visual Basic so I can create some rules and forms in iLogic
thx
Hi there,
There are loads of ways to do this. Here is one:
Sub Demo()
Dim Length As Double
Dim Range As Double
    Length = 144
    Range = 8
    MsgBox (Answer(Length, Range))
End Sub
Function Answer(L As Double, R As Double)
    Answer = L / R
End Function
This should be a start for you
Cheers
Jon.
Thanks Jon
- can this be done within the parameters instead of iLogic?
Yes, it's not difficult, but can be tricky and frustrating! Parameters can be pretty fickle when it comes to units.
If you have:
d0 = Length (in)
d1 = Range (in)
d2 = Answer/Segments (ul)
Note that the inch units cancel each other to give a unitless value (in/in = ul).
Cheers
Jon.
