• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Accepted Solution
    Divide a segment equally with a range in visual basic
    49 Views, 3 Replies
    01-15-2013 05:44 PM
    How do you divide a segment equally with a range in visual basic?
    example-
    length is 144 in
    range- 7.5 - 9in
    answer- (18) at (range 8 in)
    like to know how to do this in Visual Basic so I can create some rules and forms in iLogic
    thx
    Please use plain text.
    Valued Contributor
    jonbrabbs
    Re: Divide a segment equally with a range in visual basic
    01-15-2013 11:48 PM in reply to: heyjude19
    Hi there,
    There are loads of ways to do this. Here is one:
    Sub Demo()
    Dim Length As Double
    Dim Range As Double
        Length = 144
        Range = 8
        MsgBox (Answer(Length, Range))
    End Sub
    Function Answer(L As Double, R As Double)
        Answer = L / R
    End Function
    This should be a start for you
    Cheers
    Jon.
    If this post helps you, please give kudos.
    01-16-2013 04:34 AM in reply to: jonbrabbs
    Thanks Jon
    - can this be done within the parameters instead of iLogic?
    Valued Contributor
    jonbrabbs
    01-16-2013 06:55 AM in reply to: heyjude19
    Yes, it's not difficult, but can be tricky and frustrating! Parameters can be pretty fickle when it comes to units.
    If you have:
    d0 = Length (in)
    d1 = Range (in)
    d2 = Answer/Segments (ul)
    Note that the inch units cancel each other to give a unitless value (in/in = ul).
    Cheers
    Jon.
