Dim Errors in Model by VBA Code
Hi All,
I am using below code to create a Rectangle 4 mm X 3 mm x 1 mm, I am using mm template but the model shows 40 mm X 30 mm x 10 mm.
Anything wrong in my code, please someone guide me to understand this type of situation.
Private Sub CommandButton1_Click()
    Dim oProjectMgr As DesignProjectManager
    Set oProjectMgr = ThisApplication.DesignProjectManager
    Dim oTemplatesPath As String
   oTemplatesPath = "C:\Program Files\Autodesk\Inventor 2009\Inventor 2009\Templates\FB\AES_Standard.ipt"
    Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject, oTemplatesPath, True)
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    Dim oRectangleLines As SketchEntitiesEnumerator
    Set oRectangleLines = oSketch.SketchLines.AddAsTwoPointRectangle( _
                                oTransGeom.CreatePoint2d(0,0), _
                                oTransGeom.CreatePoint2d(4,3))
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    Dim oExtrude As ExtrudeFeature
    Set oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent( _
                        oProfile, 1, kNegativeExtentDirection, kJoinOperation)
Thanks & Regards,
S.Sekar
nmunro
Internally, Inventor uses cm for all distances, radians for all angles. Look up the UnitsOfMeasure interface
https://c3mcad.com
Yes Thanks a lot, Please let me know how to change all dim to mm insted of cm.
Thanks & Regards,
S.Sekar
skyngu
1 cm = 10 mm
Autodesk Inventor Professional 2019
Hi Jcneal,
Well thanks, how to code this to get mm valus while giving co-ordinates.
For example:
co-ordinates (4,3) the actual sketch shows 40mm X 30 mm rectangle.
Actually we need co-ordinates (4,3) as 4 mm X 3 mm rectangle sketch.
