• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Member
    Dialog on OnSaveDocument
    66 Views, 1 Replies
    01-31-2013 03:15 AM
    I try to open a Form that i create in the OnSaveDocument Event. I tested the Event with some MessageBox, they show up succesfully.
    The Problem, My Form does not show on Screen.
            Private Sub m_appEvents_OnSaveDocument(ByVal DocumentObject As Inventor.Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) _
                                      Handles m_appEvents.OnSaveDocument
                If BeforeOrAfter = EventTimingEnum.kBefore Then
                    If DocumentObject.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or DocumentObject.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                        CheckCustomiProperty(DocumentObject, "Name englisch", "")
                        CheckCustomiProperty(DocumentObject, "BENKEY", "")
                        Dim oUDProps As PropertySet
                        oUDProps = DocumentObject.PropertySets.Item(4)
                        Dim oProps As PropertySet
                        oProps = DocumentObject.PropertySets.Item(3)
                        If oUDProps.Item("Name englisch").Value = ""
                            MsgBox(oUDProps.Item("Name englisch").Value)
                            MsgBox(oUDProps.Item("BENKEY").Value)
                            MsgBox(oProps.Item(2).Value)
                            MyForm.Show()
                            MyForm.TopMost = True
                        End If
                    End If
                End If
            End Sub
    The Important Part is:
    'WORKS
    'DONT WORK
                            MyForm.Show()
     Thank you for your help, is it possible to show the Dialog ?
    Best Regards Mathias
    Please use plain text.
    ADN Support Specialist
    Re: Dialog on OnSaveDocument
    02-05-2013 07:15 AM in reply to: mziegler
    I think you need to make Inventor the parent for your form.
    Will you please look into this discussion:
    http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Can-t-tab-through-Add-in-form/m-p/2528...
     Here is the source text of WindowWrapper class provided by Josh_Petitt
        ''' <summary>
        ''' Used to wrap a Win32 hWnd as a .Net IWind32Window class.
        ''' This is primarily used for parenting a dialog to the Inventor window.
        ''' </summary>
        ''' <remarks>
        ''' For example:
        ''' myForm.Show(New WindowWrapper(m_inventorApplication.MainFrameHWND))
        ''' </remarks>
        Public Class WindowWrapper
            Implements System.Windows.Forms.IWin32Window
            Public Sub New(ByVal handle As IntPtr)
                _hwnd = handle
            End Sub
            Public ReadOnly Property Handle() As IntPtr _
              Implements System.Windows.Forms.IWin32Window.Handle
                Get
                    Return _hwnd
                End Get
            End Property
            Private _hwnd As IntPtr
        End Class
    Vladimir Ananyev
    Developer Technical Services
    Autodesk Developer Network
