Autodesk Inventor Customization
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Custom/use r properties in view label of drawing template/s tyle library?
- Highlight
- Email to a Friend
Is there a way that we can set the view label in the style library to show custom/user Properties?
We have set our iam/ipt templates to have some custom properites which we wish to display in the view label when the view is created however there this no way to add these properties to the label.
I find this a little strange as you can add these user Properties to the parts list in the style library? (I've added some screen caps to show what I am talking about)
Is there any way I can do this?
Cheers, Mick
Re: Custom/use r properties in view label of drawing template/s tyle library?
- Highlight
- Email to a Friend
Hi grinderz,
You can find some code to set an iProperty to the view label at this link:
http://inventortrenches.blogspot.com/2012/01/set-y
I hope this helps.
Curtis
- Highlight
- Email to a Friend
Thanks Curtis for the reply & the link.
Just one more question with a yes/no/maybe answer
- can ilogic be used to not only change the Veiw name as per your link but to actually add custom/user properties into the view label text?
Cheers, Mick
- Highlight
- Email to a Friend
Hi grinderz,
Here's a version that adds a custom iProperty to the existing view label. Note that the custom iProperty needs to exist in the model (or course).
I hope this helps.
Curtis
'start of ilogic code Dim oDoc As DrawingDocument: oDoc = ThisDoc.Document Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView oSheets = oDoc.Sheets For Each oSheet In oSheets oViews = oSheet.DrawingViews For Each oView In oViews 'capture the current view label ViewLabel = oView.Name oModelName = _ oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName Try o_iProp = iProperties.Value(oModelName, "Custom", "My_iProp") 'add the the iProperty to the current view label, with a dash separator oView.Name = ViewLabel & " - " & o_iProp Catch 'do nothing if error End Try Next Next 'end of ilogic code
- Highlight
- Email to a Friend
thanks again Curtis.
Sorry to be a pain but I guess I haven't explained myself very well or used the wrong terminology. I don't want to change the view label name but actually place custom properties in the view label text when the base view is created, please see attached - can this be done?
Cheers, Mick
- Highlight
- Email to a Friend
Hi grinderz,
I see. I think I was just not reading carefully.
I didn't spend too much time on this but I did come up with a bit of a hack solution, that might work for you (but I sort of doubt it as it has a big flaw). But I'm going to post what I have and hope that someone else might jump in and provide the missing part.
The hack comes in two parts, first is just a rule that will get the custom iProperty ID and formatting from a view. So you'll want to edit your drawing view and add the custom iProperty to it as such:
Then you can use this rule to get the ID and format for the custom iProperty:
'Get custom iProp format and ID from view label
Dim oSheet As Sheet
ViewLabel = oView.Label
oModelName = _
Try
'return the value
MessageBox.Show(oView.Label.FormattedText , "iLogic")
'write the value to the drawings comments property
iProperties.Value("Summary", "Comments") = oView.Label.FormattedText
Catch
End Try
Next
Next
'end of ilogic code
Then you can look in the drawings comments property and find the string to use in the next rule for that iProperty:
So copy that string and enter it in this code, replacing the custom iProperty I have entered:
'Set View Label to use custom iProp 2
'start of ilogic code Dim oDoc As DrawingDocument: oDoc = ThisDoc.Document Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView oSheets = oDoc.Sheets For Each oSheet In oSheets oViews = oSheet.DrawingViews For Each oView In oViews 'capture the current view label ViewLabel = oView.Label oModelName = _ oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName Try 'gets the custom iproperty from the model and formats it to be dynamic (uses <Br/> as a line break o_iProp_1= _ "<Property Document='model' PropertySet='User Defined Properties' Property='My_iProp_1' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='11'>My_iProp_1</Property><Br/>" 'add the the iProperty to the current view label, with a dash separator oView.Label.FormattedText = "<DrawingViewName/><Br/>" & o_iProp_1 Catch 'do nothing if error End Try Next Next 'end of ilogic code
Repeat this if you have multiple custom iProperties to use and combine them in the formatted text line as such:
oView.Label.FormattedText = "<DrawingViewName/><Br/>" & o_iProp_1 & o_iProp_2
You can remove "<DrawingViewName/><Br/>" if you don't intend for the view label to use the view name.
Note too that <Br/> provides a line return.
I doubt this is really a solution becuase the custom iProperty could have a different ID number in different model files. For instance my example shows that My_iProp_1 has a PropertyID of 11 for the current part. But I might have another part where My_iProp_1 has a PropertyID of 2.
So what is really needed is some code to return the property ID number and insert that into the string, so that the rule will work in all cases. I tried a couple of things with PropId but never did get the details worked out. I might get back to this later, but I thought this might help in the meantime.
I hope this helps.
Curtis
- Highlight
- Email to a Friend
Hi grinderz,
Okay nevermind the previous post, I was able to get this sorted out. Here's the code and a couple of sample files.
I hope this helps.
Curtis
oModel = ThisDoc.ModelDocument
Dim oSheet As Sheet
oView.ShowLabel = true
Try
'get the property ID for these custom iProperties from the model referenced by the view
o_iPropID_1 = oModel.PropertySets.Item("User Defined Properties").Item("My_iProp_1").PropId
o_iPropID_2 = oModel.PropertySets.Item("User Defined Properties").Item("My_iProp_2").PropId
Catch
'here you could add a message that one or more of the custom iProperties were not found
End Try
Try
'format the custom iproperty string and add the property ID
oString1 = "<Property Document='model' PropertySet='User Defined Properties' " _
& "Property='My_iProp_1' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
& o_iPropID_1 & "'>My_iProp_1</Property><Br/>"
oString2 = "<Property Document='model' PropertySet='User Defined Properties' " _
& "Property='My_iProp_2' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
& o_iPropID_2 & "'>My_iProp_2</Property><Br/>"
'add the custom iproperties to the view label
oView.Label.FormattedText = "<DrawingViewName/><Br/>" & oString1 & oString2
Catch
End Try
Next
Next
'end of ilogic code
- Highlight
- Email to a Friend
Hi Curtis,
Thanks so much for the solution and sample files, this is exactly what I was after and apreaciate the time you have spent.
Regards, Mick
- Highlight
- Email to a Friend
Is there a way I can get the projection orientation label as the "view" name without manually editing each label?
