• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Active Member
    Accepted Solution
    Custom/user properties in view label of drawing template/style library?
    1222 Views, 8 Replies
    04-18-2012 08:32 PM
    Is there a way that we can set the view label in the style library to show custom/user Properties?
    We have set our iam/ipt templates to have some custom properites which we wish to display in the view label when the view is created however there this no way to add these properties to the label.
    I find this a little strange as you can add these user Properties to the parts list in the style library? (I've added some screen caps to show what I am talking about)
    Is there any way I can do this?
    Cheers, Mick
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Custom/user properties in view label of drawing template/style library?
    04-19-2012 08:07 AM in reply to: grinderz
    Hi grinderz,
    You can find some code to set an iProperty to the view label at this link:
    http://inventortrenches.blogspot.com/2012/01/set-your-drawing-view-labels-to-use.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Member
    04-19-2012 07:24 PM in reply to: Curtis_Waguespack
    Thanks Curtis for the reply & the link.
    Just one more question with a yes/no/maybe answer :smileyhappy: - can ilogic be used to not only change the Veiw name as per your link but to actually add custom/user properties into the view label text?
    Cheers, Mick
    *Expert Elite*
    Curtis_Waguespack
    04-20-2012 08:15 AM in reply to: grinderz
    Hi grinderz,
    Here's a version that adds a custom iProperty to the existing view label. Note that the custom iProperty needs to exist in the model (or course).
    I hope this helps.
    Curtis
    'start of ilogic code
    Dim oDoc As DrawingDocument:  oDoc = ThisDoc.Document
    Dim oSheets As Sheets
    Dim oSheet As Sheet
    Dim oViews As DrawingViews
    Dim oView As DrawingView
    oSheets = oDoc.Sheets
    For Each oSheet In oSheets
    oViews = oSheet.DrawingViews
    	For Each oView In oViews
    	'capture the current view label
    	ViewLabel = oView.Name
    	oModelName = _
    	oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
    	Try
    	o_iProp = iProperties.Value(oModelName, "Custom", "My_iProp")
    	'add the the iProperty to the current view label, with a dash separator
    	oView.Name = ViewLabel & " - " & o_iProp
            Catch
    	'do nothing if error
    	End Try
    	Next
    Next
    'end of ilogic code
    Active Member
    04-22-2012 05:25 PM in reply to: Curtis_Waguespack
    thanks again Curtis.
    Sorry to be a pain but I guess I haven't explained myself very well or used the wrong terminology. I don't want to change the view label name but actually place custom properties in the view label text when the base view is created, please see attached - can this be done?
    Cheers, Mick
    *Expert Elite*
    Curtis_Waguespack
    04-23-2012 12:58 PM in reply to: grinderz
    Hi grinderz,
    I see. I think I was just not reading carefully.
    I didn't spend too much time on this but I did come up with a bit of a hack solution, that might work for you (but I sort of doubt it as it has a big flaw). But I'm going to post what I have and hope that someone else might jump in and provide the missing part.
    The hack comes in two parts, first is just a rule that will get the custom iProperty ID and formatting from a view. So you'll want to edit your drawing view and add the custom iProperty to it as such:
    Then you can use this rule to get the ID and format for the custom iProperty:
    'Get custom iProp format and ID from view label
    Dim oSheet As Sheet
        ViewLabel = oView.Label
        oModelName = _
        Try
        'return the value
        MessageBox.Show(oView.Label.FormattedText , "iLogic")
        'write the value to the drawings comments property
        iProperties.Value("Summary", "Comments") = oView.Label.FormattedText
        Catch
        End Try
        Next
    Next
    'end of ilogic code
    Then you can look in the drawings comments property and find the string to use in the next rule for that iProperty:
    So copy that string and enter it in this code, replacing the custom iProperty I have entered:
    'Set View Label to use custom iProp 2
    'start of ilogic code Dim oDoc As DrawingDocument: oDoc = ThisDoc.Document Dim oSheets As Sheets Dim oSheet As Sheet Dim oViews As DrawingViews Dim oView As DrawingView oSheets = oDoc.Sheets For Each oSheet In oSheets oViews = oSheet.DrawingViews For Each oView In oViews 'capture the current view label ViewLabel = oView.Label oModelName = _ oView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName Try 'gets the custom iproperty from the model and formats it to be dynamic (uses <Br/> as a line break o_iProp_1= _ "<Property Document='model' PropertySet='User Defined Properties' Property='My_iProp_1' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='11'>My_iProp_1</Property><Br/>" 'add the the iProperty to the current view label, with a dash separator oView.Label.FormattedText = "<DrawingViewName/><Br/>" & o_iProp_1 Catch 'do nothing if error End Try Next Next 'end of ilogic code
     Repeat this if you have multiple custom iProperties to use and combine them in the formatted text line as such:
    oView.Label.FormattedText = "<DrawingViewName/><Br/>"  &  o_iProp_1  &  o_iProp_2
    You can remove "<DrawingViewName/><Br/>"  if you don't intend for the view label to use the view name.
    Note too that <Br/> provides a line return.
    I doubt this is really a solution becuase the custom iProperty could have a different ID number in different model files. For instance my example shows that My_iProp_1 has a PropertyID of 11 for the current part. But I might have another part where  My_iProp_1 has a PropertyID of 2.
    So what is really needed is some code to return the property ID number and insert that into the string, so that the rule will work in all cases. I tried a couple of things with PropId but never did get the details worked out. I might get back to this later, but I thought this might help in the meantime.
    I hope this helps.
    Curtis
    *Expert Elite*
    Curtis_Waguespack
    04-23-2012 02:33 PM in reply to: Curtis_Waguespack
    Hi grinderz,
    Okay nevermind the previous post, I was able to get this sorted out. Here's the code and a couple of sample files.
    I hope this helps.
    Curtis
    oModel = ThisDoc.ModelDocument
    Dim oSheet As Sheet
    	oView.ShowLabel = true
    		Try
    		'get the property ID for these custom iProperties from the model referenced by the view
    		o_iPropID_1 = oModel.PropertySets.Item("User Defined Properties").Item("My_iProp_1").PropId
    		o_iPropID_2 = oModel.PropertySets.Item("User Defined Properties").Item("My_iProp_2").PropId
    		Catch
    		'here you could add a message that one or more of the custom iProperties were not found
    		End Try
    		Try
    		'format the custom iproperty string and add the property ID
    		oString1 = "<Property Document='model' PropertySet='User Defined Properties' " _
    		&  "Property='My_iProp_1' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
    		& o_iPropID_1  & "'>My_iProp_1</Property><Br/>"
    		oString2 = "<Property Document='model' PropertySet='User Defined Properties' " _
    		&  "Property='My_iProp_2' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='" _
    		& o_iPropID_2  & "'>My_iProp_2</Property><Br/>"
    		'add the custom iproperties to the view label
    		oView.Label.FormattedText = "<DrawingViewName/><Br/>"  &  oString1 &  oString2
    		Catch
    		End Try
    	Next
    Next
    'end of ilogic code
    Active Member
    04-23-2012 03:51 PM in reply to: Curtis_Waguespack
    Hi Curtis,
    Thanks so much for the solution and sample files, this is exactly what I was after and apreaciate the time you have spent.
    Regards, Mick
    Active Member
    04-25-2012 01:25 PM in reply to: grinderz
    Is there a way I can get the projection orientation label as the "view" name without manually editing each label?
