• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Valued Contributor
    Accepted Solution
    Custom Table coming out with garbled text ??
    92 Views, 2 Replies
    09-20-2012 08:30 AM
    I am using VB.net to generate a custom table in my .idw files to make a plot stamp.  The table is showing up, however, the text is garbled.  When you open the .idw, the table properties show the text correctly but the display is coming out messed up.  I have attached a picture of what each looks like.  I moved the table off the sheet for clarity.
    The code:
    Public Sub PlotStamp()
            Dim oDrawDoc As DrawingDocument
            oDrawDoc = _invApp.ActiveDocument
            Dim oInvSheet As Sheet
            oInvSheet = oDrawDoc.ActiveSheet
            Dim oTitles_Plot(0) As String
            oTitles_Plot(0) = CurrentFilename
            Dim position_Plot As Point2d = _invApp.TransientGeometry.CreatePoint2d((oInvSheet.Border.RangeBox.MinPoint.X), (oInvSheet.Border.RangeBox.MinPoint.Y - 0.125))
            Dim oCustomTable_Plot As CustomTable
            oCustomTable_Plot = oInvSheet.CustomTables.Add(" ", position_Plot, 1, 1, oTitles_Plot)
            oCustomTable_Plot.ShowTitle = False
            oCustomTable_Plot.Columns.Item(1).TitleHorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft
            oCustomTable_Plot.Columns.Item(1).ValueHorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft
            Dim oFormat_Plot As TableFormat
            oFormat_Plot = oInvSheet.CustomTables.CreateTableFormat
            oFormat_Plot.OutsideLineColor = _invApp.TransientObjects.CreateColor(255, 255, 255)
            oFormat_Plot.InsideLineColor = _invApp.TransientObjects.CreateColor(255, 255, 255)
            oCustomTable_Plot.OverrideFormat = oFormat_Plot
        End Sub
     Where CurrentFilename is:
    CurrentFilename = (CurrentDirectory & "\Submittal_Sheet_" & drawing_count & ".pdf")
    Please use plain text.
    ADN Support Specialist
    Re: Custom Table coming out with garbled text ??
    09-25-2012 04:01 AM in reply to: nickv02
    I can reproduce this problem in Inventor 2013.
    You are right – strings with combinations of backslash “\” with some characters (e.g., \T, \S, etc.) are displayed with defects in custom table and column titles.  Sorry.
    As a temporary workaround you may consider the following convertor for this kind of strings in column titles:
    Function TransformTitle(ByVal St As String) As String
      Dim ChArray() As Char = { _
            "A"c, "B"c, "C"c, "F"c, "G"c, "H"c, _
            "I"c, "L"c, "O"c, "S"c, "T"c, "W"c, _
            "X"c, "Y"c, "b"c, "c"c, "f"c, "i"c, _
            "l"c, "o"c, "q"c, "x"c, "y"c}
      For Each Ch As Char In ChArray
        St = St.Replace("\" & Ch, "\\" & Ch)
      Next
      Return St
    End Function
    Changes in your code:
    oTitles_Plot(0) = TransformTitle(CurrentFilename)
    Thank you very much for this case.
    Vladimir Ananyev
    Developer Technical Services
    Autodesk Developer Network
    Valued Contributor
    09-25-2012 05:40 AM in reply to: Vladimir.Ananyev
    That fixed the garbled text.  Thank you for the solution !
