08:30 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using VB.net to generate a custom table in my .idw files to make a plot stamp. The table is showing up, however, the text is garbled. When you open the .idw, the table properties show the text correctly but the display is coming out messed up. I have attached a picture of what each looks like. I moved the table off the sheet for clarity.
The code:
Public Sub PlotStamp()
Dim oDrawDoc As DrawingDocument
oDrawDoc = _invApp.ActiveDocument
Dim oInvSheet As Sheet
oInvSheet = oDrawDoc.ActiveSheet
Dim oTitles_Plot(0) As String
oTitles_Plot(0) = CurrentFilename
Dim position_Plot As Point2d = _invApp.TransientGeometry.CreatePoint2d((oInvSheet.Border.RangeBox.MinPoint.X), (oInvSheet.Border.RangeBox.MinPoint.Y - 0.125))
Dim oCustomTable_Plot As CustomTable
oCustomTable_Plot = oInvSheet.CustomTables.Add(" ", position_Plot, 1, 1, oTitles_Plot)
oCustomTable_Plot.ShowTitle = False
oCustomTable_Plot.Columns.Item(1).TitleHorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft
oCustomTable_Plot.Columns.Item(1).ValueHorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextLeft
Dim oFormat_Plot As TableFormat
oFormat_Plot = oInvSheet.CustomTables.CreateTableFormat
oFormat_Plot.OutsideLineColor = _invApp.TransientObjects.CreateColor(255, 255, 255)
oFormat_Plot.InsideLineColor = _invApp.TransientObjects.CreateColor(255, 255, 255)
oCustomTable_Plot.OverrideFormat = oFormat_Plot
End SubWhere CurrentFilename is:
CurrentFilename = (CurrentDirectory & "\Submittal_Sheet_" & drawing_count & ".pdf")
