Create a new Inventor DWG drawing using VB.NET
Hello.
I'm trying to create a new DWG file in Inventor.
In the Inventor options I changed the default file type of drawing, but when I add a new document using the Add method from the Documents collection, always creates a file of type IDW.
I tried to force the option from code, but I get the same result.
I am using VB.net 2008 and Inventor 2010, this is the code:
InvApp = InventorGet()
InvApp.Visible = True
InvApp.DrawingOptions.DefaultDrawingFileType = DefaultDrawingFileTypeEnum.kDWGDefaultDrawingFileType
InvDoc = InvApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject)
Any ideas? Thanks in advance
Dennis.Ossadnik
Autodesk Support
Autodesk Support
Hi jgaston,
you could use it like that and specify the template file:
Dim InvDoc As Document
Set InvDoc = InvApp.Documents.Add(kDrawingDocumentObject, "C:\Templates\Norm.dwg", True)
Hope, this helps.
Dennis Ossadnik
Senior Technical Support Specialist
Thanks Dennis, but hoped to use the default template and not have to deal with code to manage the routes.
If I understand, the help of the API says the method should work this way.
Regards
Dennis.Ossadnik
Autodesk Support
Autodesk Support
Hi jgaston
Here is an exaple how you can use the standard templates:
first set the option: DrawingOptions.DefaultDrawingFileType = kDWGDefaultDrawingFileType
then get your template: FileManager.GetTemplateFile(kDrawingDocumentObject, kDefaultSystemOfMeasure, kDefault_DraftingStandard, "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}")
use this template in the way i mentioned:
Documents.Add(kDrawingDocumentObject, TemplateNameDWG, True)
Example:
This code will add two new drawing douments to inventor. One dwg, one idw.
Dim InvApp As Application
Set InvApp = ThisApplication
'Get name of DWG Tamplate
InvApp.DrawingOptions.DefaultDrawingFileType = kDWGDefaultDrawingFileType
Dim TemplateNameDWG As String
TemplateNameDWG = InvApp.FileManager.GetTemplateFile(kDrawingDocumentObject, kDefaultSystemOfMeasure, kDefault_DraftingStandard, "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}")
'Get name of idw template
InvApp.DrawingOptions.DefaultDrawingFileType = kIDWDefaultDrawingFileType
Dim TemplateNameIDW As String
TemplateNameIDW = InvApp.FileManager.GetTemplateFile(kDrawingDocumentObject, kDefaultSystemOfMeasure, kDefault_DraftingStandard, "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}")
'New DWG
Dim oDocDWG As Document
Set oDocDWG = InvApp.Documents.Add(kDrawingDocumentObject, TemplateNameDWG, True)
'New IDW
Dim oDocIdw As Document
Set oDocIdw = InvApp.Documents.Add(kDrawingDocumentObject, TemplateNameIDW, True)
I hope this works for you.
Dennis Ossadnik
Thank you very much Denis
I manage with this.
Just one question, the GUID "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}" what type of document referred to? where I can find a list of GUID's valid for this function?
Best regards and thank you very much again.
Josh_Hunt
Hi @Anonymous and @Dennis.Ossadnik
A decade later and this is still a bug if the documentation https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-66A32241-D9C0-4E9D-B6D1-F4A9DA1F69F9 is c...
Thank you for the workaround. However I now have to 'clean' the document of all Drawing Resources and styles before I can build from scratch.
BACKGROUND: I have a corrupt DWG template and I am trying to rebuild it using API to transfer all the content over. Not simple but possible.
Josh Hunt
