Copy iProperties from IPT to IDW
Message 1 of 8
We have a need to copy all of our iProperties from the model into the
IDW. I would like to do this on save of the file to make it seemless to the
user. We need to do this to help satisfy our document management software,
synergis adept. In Adept they have what they call a library card that gets
populated from the iProperties and since an IDW has no information in the
iProperties, it's all driven from the part, there is no information on the
library card. Adept has compensated for this by allowing the user to copy
those iProps after a file is signed in but it is a manual proccess. You
have to selecet the file in Adept and fire off the command, it works but
prone to being forgotten. So what I am asking for, since I am a hacker with
vba at best, is if anyone has some sample code they might be willing to
provide to get me started. Anything you have would be greatly appreciated,
thanks.
Corey
Replies (7)
Message 2 of 8
So I guess no one does this at all currently?
"Corey Parks" wrote in message
news:[email protected]...
thanks.
Corey
Message 3 of 8
Hi Corey,
Help actually covers iProperties pretty well. You are going to need to make
a addin, with a onSave event. You can't do it in VBA.
I am not sure, but is there a 100% direct correlation between part/assembly
files iProps and drawing iProps? If there is, you should just be able to
iterate through the part/assembly's iProps, and copy the values to the
drawings iProps... If not, you need to deal with the differences somehow.
Do all your drawing only contain views of one part or assembly?
KWiKMcad
Kent Keller
thanks.
Corey
Message 4 of 8
No, they contain views of multiple files but the first inserted view is the
one that defines the title block information, which is what I would like to do
for this as well.  The first view inserted will define the parts used to
update the IDW iProps.  My skill level is not very high in this kind of
thing as of yet so this one might be beyond my abilities.  I have been
looking to find any kind of code that does something similar but have not found
anything in the help files or elsewhere.  With a piece of code that I know
what it does I can usually pick it apart and figure out the functionality and
then modify it for my own ends.  I guess what I really need to do is take
some more classes on vb to get this figured out.
Hi
Corey,
to need to make
VBA.
part/assembly
the values to the
or assembly?
KWiKMcad
Kent Keller
"Corey Parks" <Reply in
group only> wrote in message
href="news:[email protected]">news:[email protected]
So
We
IDW.
the
software,
card that gets
information in the
information on the
thanks.
Corey
Message 5 of 8
Cory,
here is a start.
If you want just want someone to write it,
 I am always looking for little jobs.  feel free to contact me.
Public Sub iProps()
Dim oDoc As DrawingDocument
Set oDoc =
ThisApplication.ActiveDocument
Dim oviewdoc As Document
Set oviewdoc =
oDoc.Sheets(1).DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
Dim oViewPropSets As PropertySets
Set oViewPropSets =
oviewdoc.PropertySets
Dim oViewPropSet As PropertySet
Dim oViewProp As Property
Dim oDocProp As Property
For Each oViewPropSet In oViewPropSets
    For Each oViewProp In oViewPropSet
    On Error Resume
Next
oDoc.PropertySets(oViewPropSet.InternalName).ItemByPropId(oViewProp.PropId).Value
= oViewProp.Value
    If Error
Then
Err.Clear
    End If
    Next
Next
End Sub
KWiKMcad
Kent Keller
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px"
dir=ltr>
"Corey Parks" <Reply in group only> wrote in message
the one that defines the title block information, which is what I would like
to do for this as well.  The first view inserted will define the parts
used to update the IDW iProps.  My skill level is not very high in this
kind of thing as of yet so this one might be beyond my abilities.  I have
been looking to find any kind of code that does something similar but have not
found anything in the help files or elsewhere.  With a piece of code that
I know what it does I can usually pick it apart and figure out the
functionality and then modify it for my own ends.  I guess what I really
need to do is take some more classes on vb to get this figured out.
Hi
Corey,
in VBA.
part/assembly
part or assembly?
KWiKMcad
Kent Keller
"Corey Parks"
So
We
the
seemless to the
provide to get me
appreciated,
thanks.
Corey
Message 6 of 8
Well it's going ok so far, at least I am learning a
bit but I ran into a problem.  I am trying to copy specific iprops from one
file to the other and I have all but the "Company" field working.  I have
no idea whay that one won't copy as I can copy other fields from that tab.
Anyone have any ideas?
Public Sub CopyiPropsToIDW()
Set oDoc =
Set
oviewdoc =
Dim
Set oViewPropSets =
Dim
Dim oDocProp As
Property
 CustomProps
oDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Description").Value
oviewdoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Description").Value
oDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Vendor").Value
oviewdoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Vendor").Value
oDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Cost
Center").Value =
oviewdoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").Item("Cost
Center").Value
oDoc.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").Item("Comments").Value
oviewdoc.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").Item("Comments").Value
oDoc.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").Item("Company").Value
oviewdoc.PropertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}").Item("Company").Value
        oDoc.PropertySets("User Defined
Properties").Item("Equipment Type").Value = oviewdoc.PropertySets("User Defined
Type").Value
oDoc.PropertySets("User Defined Properties").Item("Line Name").Value =
oviewdoc.PropertySets("User Defined Properties").Item("Line
Name").Value
oDoc.PropertySets("User Defined Properties").Item("Asset Number").Value =
oviewdoc.PropertySets("User Defined Properties").Item("Asset
Number").Value
End Sub
dir=ltr>
Cory,
here is a start.
Public Sub iProps()
Set oDoc =
Set oviewdoc =
Set oViewPropSets =
oViewPropSet
    On Error Resume
Next
= oViewProp.Value
    If Error
Then
Err.Clear
    End If
    Next
Next
End Sub
KWiKMcad
Kent Keller
dir=ltr>
have been looking to find any kind of code that does something similar but
have not found anything in the help files or elsewhere.  With a piece
of code that I know what it does I can usually pick it apart and figure out
the functionality and then modify it for my own ends.  I guess what I
really need to do is take some more classes on vb to get this figured
out.
Hi
Corey,
it in VBA.
KWiKMcad
Kent
Keller
So
"Corey Parks"
We
the
seemless to the
library card.  Adept
those iProps after
have to
prone to
with
to
appreciated,
thanks.
Corey
Message 7 of 8
Try
oDoc.PropertySets("{D5CDD502-2E9C-101B-9397-08002B2CF9AE}").Item("Company").Value
oViewDoc.PropertySets("{D5CDD502-2E9C-101B-9397-08002B2CF9AE}").Item("Company").Value
KWiKMcad
Kent Keller
dir=ltr>
a bit but I ran into a problem.  I am trying to copy specific iprops from
one file to the other and I have all but the "Company" field working.  I
have no idea whay that one won't copy as I can copy other fields from that
tab.  Anyone have any ideas?
Public Sub
CopyiPropsToIDW()
Set oDoc =
Set
oviewdoc =
Dim
Set oViewPropSets =
Dim
Dim oDocProp As
Property
 CustomProps
Center").Value =
Center").Value
Defined Properties").Item("Equipment
Type").Value
Name").Value
Number").Value
End Sub
dir=ltr>
Cory,
here is a start.
Public Sub iProps()
Set oDoc =
Set oviewdoc =
Set oViewPropSets =
oViewPropSet
    On Error Resume
Next
= oViewProp.Value
    If Error
Then
Err.Clear
    End If
    Next
Next
End Sub
KWiKMcad
Kent Keller
dir=ltr>
is the one that defines the title block information, which is what I would
like to do for this as well.  The first view inserted will define the
parts used to update the IDW iProps.  My skill level is not very high
in this kind of thing as of yet so this one might be beyond my
abilities.  I have been looking to find any kind of code that does
something similar but have not found anything in the help files or
elsewhere.  With a piece of code that I know what it does I can
usually pick it apart and figure out the functionality and then modify it
for my own ends.  I guess what I really need to do is take some more
Hi
Corey,
it in VBA.
iterate through the
drawings iProps...
Do all your
KWiKMcad
Kent Keller
wrote in message
So
"Corey Parks"
We
the
seemless to the
library card.  Adept
those iProps
have
but
a hacker with
be willing to
thanks.
Corey
Message 8 of 8
Thanks didn't realize top and bottom of the window
on that tab had different internal Id's.  Works great now.
dir=ltr>
Try
KWiKMcad
Kent Keller
dir=ltr>
learning a bit but I ran into a problem.  I am trying to copy specific
iprops from one file to the other and I have all but the "Company" field
working.  I have no idea whay that one won't copy as I can copy other
fields from that tab.  Anyone have any ideas?
Public Sub
CopyiPropsToIDW()
Set oDoc =
Set
oviewdoc =
Dim
Set oViewPropSets =
Dim
Dim oDocProp As
Property
 CustomProps
Center").Value =
Center").Value
Defined Properties").Item("Equipment Type").Value =
oviewdoc.PropertySets("User Defined Properties").Item("Equipment
Type").Value
Name").Value
Number").Value
End Sub
dir=ltr>
Cory,
here is a start.
it,  I am always looking for little jobs.  feel free to contact
me.
Public Sub iProps()
Set oDoc =
Set oviewdoc =
Set oViewPropSets =
oViewPropSet
    On Error Resume
Next
= oViewProp.Value
    If Error
Then
Err.Clear
    End If
    Next
Next
End Sub
KWiKMcad
Kent Keller
dir=ltr>
view is the one that defines the title block information, which is what
I would like to do for this as well.  The first view inserted will
define the parts used to update the IDW iProps.  My skill level is
not very high in this kind of thing as of yet so this one might be
beyond my abilities.  I have been looking to find any kind of code
that does something similar but have not found anything in the help
files or elsewhere.  With a piece of code that I know what it does
I can usually pick it apart and figure out the functionality and then
Hi
Corey,
can't do it in VBA.
iterate
somehow.
assembly?
KWiKMcad
Kent Keller
"Corey Parks"
So
"Corey Parks"
We
the
seemless to the
populated from the
iProperties,
library
copy
proccess.  You
provide to get me
appreciated,
thanks.
Corey
