Convert model parameter to reference parameter
I need to convert a model parameter to a reference parameter thru the API.
I saw this item discussed in the group before, but I cant find the thread.
Can anyone help me out?
jletcher
Property Driven() As VARIANT_BOOL
Sorry, I didn't get that answer.
Has anyone put the " ModelParameter.Convert to Reference Parameter" Method?
Vladimir.Ananyev
ConvertToReferenceParameter method works fine but not for built-in model parameters. See help.   If you create model parameter programmatically then you are free to call this method. Try the following VBA sample.
Private Sub Model2Refs_1()
  Dim oDef As PartComponentDefinition
  Set oDef = ThisApplication.ActiveDocument.ComponentDefinition
  Dim oPars As Parameters
  Set oPars = oDef.Parameters
  Dim oModelPars As ModelParameters
  Set oModelPars = oPars.ModelParameters
  Dim oModelPar As ModelParameter
  'create model parameter (not built-in)
  Set oModelPar = oModelPars.AddByExpression("333 mm", "mm", "NonBuiltIn")
  'change its type to reference
  Call oModelPar.ConvertToReferenceParameter
End Sub
You may control Boolean Driven property of dimension constraints. Create new part with the rectangle on the first sketch + create pair of dimensions (so you will get pair of model parameters). The following VBA code convert parameter which controls the first dimension constraint to reference type.
Private Sub Model2Refs_2()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Set oDef = oDoc.ComponentDefinition
  Dim oSketch As PlanarSketch
  Set oSketch = oDef.Sketches.Item(1)
  Dim oDims As DimensionConstraints
  Set oDims = oSketch.DimensionConstraints
  Dim oDim As TwoPointDistanceDimConstraint
  Set oDim = oDims.Item(1)
  oDim.Driven = True
End Sub
Hope the idea is clear.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Excellent answer, thank you
