Changing hole termination
Hi all,
How can I change the termination of an existing hole feature ?.
If app.ActiveDocument Is PartDocument Then
    Dim doc as PartDocument
    doc = app.ActiveDocument
    Dim hole as HoleFeature
    hole = doc.ComponentDefinition.Features.HoleFeatures(1)
End If
Pascal Langlais
nagwani
Hi Pascal,
The sample VBA code shown below changes the extent of hole from ToExtent to Through hole and vice versa.
Hope this helps!
-Ishwar N
Sub changeHoleTermination()
    Dim app As Inventor.Application
    Set app = ThisApplication
    If TypeOf app.ActiveDocument Is PartDocument Then
        Dim doc As PartDocument
        Set doc = app.ActiveDocument
        Dim def As PartComponentDefinition
        Set def = doc.ComponentDefinition
        Dim hole As HoleFeature
        Set hole = def.Features.HoleFeatures.Item(1)
        If hole.ExtentType = kToExtent Then
            ' Make it a through hole
            hole.SetThroughAllExtent (kPositiveExtentDirection)
        ElseIf hole.ExtentType = kThroughAllExtent Then
' In this sample the 4th workplane is at center of extruded part Call hole.SetToFaceExtent(def.WorkPlanes.Item(4), True) End If End If End Sub
Thank you Ishwar,
I will take a look this week-end and I'll give you feedback next week
Pascal
