• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Valued Contributor
    Accepted Solution
    Change the LOD in derived part through iLogic
    206 Views, 11 Replies
    01-27-2013 11:51 PM
    I got this code earlier from Curtis_Waguespack, and i would like to add a setting...
    When i run this rule it Derives the assembly, but LOD is set to Master, i would like it to be set to my own (Configurator) LOD...
    I don't seem to be able to find anything in this code, that defines LOD...
    So far im doing ok with the standard ilogic code, but when it´s API or VBA code im lost.. :smileyfrustrated: which leads me to this.. i've been searching the forum back and forth to find a code that performs the feature "Shrinkwrap", and somehow everything i have found so far does not work... even the code example in Inventors help menu under programming help, which several forum posts have suggested... Therefore im trying to solve this with Curtis's code as staring point.. :smileyhappy:
    'set a reference to the assembly component definintion.'this assumes an assembly document is open.Dim oAsmCompDef As AssemblyComponentDefinition
    oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    'define the path and file nameDim sPathandName As String
    sPathandName  = ThisDoc.PathAndFileName(False)
    ' Create a new part file to derive the selected part into 'note: kPartDocumentObject is the default template'you could specifiy a path and file name for a custom templateDim oPartDoc As PartDocument
    oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    'create the derived assembly deffinitionDim oDerivedAssemblyDef As DerivedAssemblyDefinition
    oDerivedAssemblyDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sPathandName & ".iam")
    'Set derive style optionsoDerivedAssemblyDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyWithSeams
    'options:    'kDeriveAsSingleBodyWithSeams     'kDeriveAsSingleBodyNoSeams     'kDeriveAsMultipleBodies     'kDeriveAsWorkSurface
    'Create the derived partDim oDerivedAssembly As DerivedAssemblyComponent
    oDerivedAssembly = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef)
    Please use plain text.
    Valued Contributor
    Re: Change the LOD in derived part through iLogic
    01-28-2013 01:41 AM in reply to: LSA-skan
    Also, where do i define if the link should be broken, supressed og kept active..?
    /LSA-Skan
    Valued Contributor
    01-28-2013 08:11 PM in reply to: LSA-skan
    If you already have Configurator LOD defined in Assembly then you to load LOD you have to use
    Configurator.active i.,e., LOD.Active
    ti will pop up save window if there are any changes in previous LOD and loads to required (configuratoe) LOD
    Cheers
    Mechanical Engineer
    Inventor Applications Engineer
    If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
    Employee
    nagwani
    01-28-2013 09:19 PM in reply to: LSA-skan
    Hi There,
    There is a bug in Inventor API documentation which states that ActiveLevelOfDetailRepresentation is read only property i.e. "Property that returns the name of the active Level of Detail Representation for the derived assembly", but ActiveLevelOfDetailRepresentation can be set as shown below. And you can break the link after Derived assembly is created.
    'Set level of Detail
    oDerivedAssemblyDef.ActiveLevelOfDetailRepresentation = "LevelOfDetail1"
    oDerivedAssembly = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAssemblyDef)..
    ' Break the link
    oDerivedAssembly..BreakLinkToFile()
    Valued Contributor
    01-28-2013 09:36 PM in reply to: nagwani
    Good To see you back on Forms Mr.Ishwar.
    This is how i did for a addin for a client and it is workng fine(till)
    is that a good way to activate MasterLOD??
    ' Back to Master Level of Detail.
    Dim oMasterLOD As LevelOfDetailRepresentation
    Set oMasterLOD = oDef.RepresentationsManager.LevelOfDetailRepresentations.Item(1)
    oMasterLOD.Activate
    And Breaking link is straight process.
    Mechanical Engineer
    Employee
    nagwani
    01-28-2013 10:30 PM in reply to: ADNpati
    Thanks, your code snippet to Activate/Switch to Master LOD is fine. The advantage with specifying LOD during shrinkwrap through ActiveLevelOfDetailRepresentation is that the API takes care of switching to specified LOD and once the derived part is created the LOD is switched backed to Master.
    -Ishwar
    Valued Contributor
    01-28-2013 10:36 PM in reply to: nagwani
    Thanks for all your replys
    The solution you provided Nagwani, worked :smileyhappy:
    however, due to my inexperience, im not sure what to put in the () in the break link line..?
    /LSA-Skan
    Valued Contributor
    01-28-2013 10:42 PM in reply to: ADNpati
    ADNpati.:
    Im not sure why you want to switch back to Master LOD, any specific reason for that..?
    The assembly im woking on should always be on my custom LOD, cause the master will not make any sense, due to the overflod of diffrent options being ontop of eachother.. :smileyhappy:
    Employee
    nagwani
    01-28-2013 10:51 PM in reply to: LSA-skan
    The derived API would consider current LOD if the ActiveLevelOfDetailRepresentation is not specified. One may have muliple LOD's and if specified LOD is not current LOD, the API takes care of switching to specified LOD and once the derived part is created it swithces to active LOD.
    -Ishwar
    Valued Contributor
    01-28-2013 11:00 PM in reply to: nagwani
    yeah, i think im with you on that... but when i used the code i posted in the original post, it changed to the master LOD regardless of what LOD was active at the time... But when i use Shrinkwrap manually, the derived was set to the Active LOD, hence the need for the line you provided :smileyhappy:
    regarding the ealier post about returning to master LOD like ADNpati, i was just wondering if there was some kind of beneficial reason for returning to master LOD..
    Could you tell me what to put in the () in..:
