• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    vampelas
    Change Drawing Dimension Text and Symbols Font with iLogic
    241 Views, 3 Replies
    11-02-2012 09:09 AM
    I was looking to change the fonts in a drawing for the Dimensions and Symbols that might have been inserted in the Dimension text entries.
    This can be done manually bu editing the dimentions text after placemement, but I was ooking to set this as a default.. I cannot see where exactly this is controlled in the Styles Manager - I am only able to change the Dimension text font but the diameter symbol font is always on AIGDT.
    I was therefore looking for an iLogic\vb code that could do the trick, but I am not able to even change the dimension fonts... The code runs with no errors but nothing gets updated in the drawing...
    Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDoc.ActiveSheet
    Dim oBaseDimSet As BaselineDimensionSet
    Dim oBaseDimSets As BaselineDimensionSets
    For Each oBaseDimSets In oSheet.DrawingDimensions.BaselineDimensionSets
        oBaseDimSet.Style.TextStyle.Font = "Chiller"
        oBaseDimSet.Style.TextStyle.FontSize = 10
    Next
    InventorVb.DocumentUpdate()
    Any idea what I am doing wrong here?
    Best Regards,
    Vas
    Please use plain text.
    Valued Mentor
    jdkriek
    Re: Change Drawing Dimension Text and Symbols Font with iLogic
    11-05-2012 05:50 AM in reply to: vampelas
    Here you go
    Dim oSheet As Sheet
    oBaseDimSets = oSheet.DrawingDimensions.BaselineDimensionSets
        For Each oBaseDimSet In oBaseDimSets
            '.396 = .156in Text
            '.458 = .180in Text
            oBaseDimSet.Style.TextStyle.FontSize = 0.458
        Next
    Jonathan D. Kriek
    Applications Engineer
    Autodesk Inventor Certified Expert
    Microsoft Certified Application Developer
    _____________________________________________________
    Did I help you? Please choose Accept as Solution or Kudos below
    vampelas
    11-05-2012 09:29 AM in reply to: jdkriek
    Hi Joh,
    Thank for the response and assitance, I knew I was forgetting something importnat in that code... Although this code still make no effect on the drawing for some reason, does that work for you on existing dimension text?
    Many thanks,
    Vas
    ADN Support Specialist
    xiaodong.liang
    11-19-2012 10:40 PM in reply to: vampelas
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
