Cannot open Inventor files with the Inventor Viewer.
This is regarding Historic Inventor version 10 files.
The Inventor Viewer 2012 does open the file.
but when I try to open the same file with the Inventor Viewer 2012 ActiveX control.
It fails with the error:
[ERROR] The database in I:\Pack_Go Inventor Files\52080-001\bracket.ipt could not be opened.
What gives?
What is the full viewer doing that the control is not?
I have made sure that apprentice is referencing the Default.ipj project file in the Viewer Install folder.
[Edit]  Just tested with an Inventor 2011 part.  Same Error.  [/Edit]
Okay,
On the off chance my development PC was toast I wiped it clean.  Reinstalled WinXP and all related software.
Installed VB6 and InventorViewer 2012.
Created a new VB Project with a Form.
1) The Viewer Control does not show up in the list of available components.  (I believe it use to.)
2) After browsing to and selecting C:\Program Files\Autodesk\Inventor 2012\Bin\InventorViewCtrl.ocx the icon shows up in the controls tool box.
Drew the control on the form.
Added a button with the following code to load an existing file.
Private Sub Command1_Click()
  InventorViewControl1.filename = "G:\ - IT Support\007.ipt"
End Sub
I receive the same error as in my last post.
Running  InventorView.exe  I can load the file into the viewer just fine.
Am I missing something?  This use to work with previous versions of inventor.
I have exact the same problem. Have you found a solution?
--Tim
Other than rolling everything back to 2011, No.
A bug report was filed with Autodesk and they verified that it was a real bug.
Said it would probably be fixed in a future version / release.
Never heard back from them.
Ok, i have found my solution:
- Install Inventor View 2012 - (the InventorViewCtrl.ocx will not work! "[ERROR] The database in [filename] could not be opened.")
- Install Inventor View 2011(!) parallel
- Start Inventor View 2011 and register (regsvr32) the InventorViewCtrl.ocx 2011-Version.
- Start Inventor View 2012 and register InventorViewCtrl.ocx back. (2012)
Now opens InventorViewCtrl.ocx Inventor 2012 files.
--Tim
While this might work with Windows 7 it does not work with Windows XP.
