Autodesk Inventor Customization
- Start Article
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Call iLogic rule from add-in
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a way to directly call an iLogic rule from within an add-in?
I have written an add-in that manipulates parameters in various sub-assemblies and now need to call various iLogic rules which the designers have written to act on the parameter changes.
ta
Gav
Re: Call iLogic rule from add-in
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The rules should run automatically when the parameters change. Is that not working the way you expect? If so, it is possible to run rules explicitly from an add-in. Is your add-in in VB.NET or C#? What version of Inventor?
Mike Deck
Software Developer
DLS - Mechanical Design
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry we are running 2011 (although I am testing in 2011 & 2012) and the add-in is written in c#. So far the rules are not running automatically but I would like more control and call the rules directly if possible anyway. Longer term the "Don't run automatically" will be set in all the rules.
thanks
Gav
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here's the way I've run rules using C#
//For Rules in documents
int rVal = 0;
iLogicRule iRule = iLogicAutomationObject.GetRule(IVDocument, ruleName);
if (iRule != null) { rVal = iLogicAutomationObject.RunRuleDirect(iRule);
//For external rules
int rVal = 0;
rVal = iLogicAutomationObject.RunExternalRule(IVDocument, ruleName);
Design Engineer / Programmer
A & A Manufacturing
Support a Q & A For CAD Users: Stack Exchange Proposal
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here's a sample C# class that links to the automation interface in the iLogic addin, and has functions to run rules. A disadvantage of this direct linking method is that you need separate versions of your addin for Inventor 2011 and 2012.
If you don't want separate versions, you can use COM late binding instead. That requires more (and messier) code.
Mike Deck
Software Developer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Perfect. Thanks very much.
