• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    YoniGaia
    Batch Save Copy As PDF with a Custom Parameter Filename
    259 Views, 2 Replies
    05-14-2012 10:14 PM
    Hi All,
    I urgently need the following:
    An application that will let me choose a group of Drawing files (.idw) and perform "Save Copy As" to a PDF format on them. The Filename of each Drawing should be extracted from a custom Parameter I embeded in the IDW file.
    I know I can use the Task Manager with a virtual PDF Printer to create these files, but then the PDF Filename will equal the IDW Filename, and I want it to be derived from the custom parameter I prepared inside the drawings.
    Please advise.
    Yoni
    Please use plain text.
    danny
    Re: Batch Save Copy As PDF with a Custom Parameter Filename
    05-16-2012 12:55 AM in reply to: YoniGaia
    in one of the blogpots of From the Trenches with Autodesk Inventor there is a post where you can find the code to export your drawings to a pdf with information like revnumber from your file. This for a start; the batching is also something I like to know.
    ilogic-to-save-pdf-files-to-new
    Danny
    Regards
    Danny
    Inventor 2013 SP1.1 | Vault basic 2013 | HP Elitebook 8670W | win7 64b | 8Gb | GMT +1
    YoniGaia
    05-16-2012 03:12 AM in reply to: YoniGaia
    Thanks Danny,
    Rule seems OK.
    The trick is: How do I run it over a group of existing IDW files without having to open each file manually?
    Yoni
