Autodesk Inventor Customization
- Start Article
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Autodesk 2013 iLogic issue with inputboxes
- Highlight
- Email to a Friend
- Report Inappropriate Content
I just couldn’t stop thinking about this. I feel that I might have cracked it finally. Here is some ilogic code that will force it to try in both French and UK English localizations. This should allow for either a comma or a decimal point for string input. You can of course set it to only do or the other using further logic, but I think that this should get us on the correct track… or at least I hope. Tell me the results of the following code.
Imports System.Globalization
Dim value As String
Dim style As NumberStyles
Dim FRculture, UKculture As CultureInfo
Dim oNumber As Decimal
' Parse currency value using en-GB culture.
value = "0.2"
style = NumberStyles.AllowDecimalPoint Or NumberStyles.AllowCurrencySymbol
'culture = CultureInfo.CreateSpecificCulture("en-GB")
'USculture = CultureInfo.CreateSpecificCulture("en-US")
FRculture = CultureInfo.CreateSpecificCulture("fr-FR")
UKculture = CultureInfo.CreateSpecificCulture("en-UK")
If Decimal.TryParse(value, style, FRculture, oNumber) = True Or Decimal.TryParse(value, style, UKculture, oNumber) = True Then
MessageBox.Show("Converted : "& value & " --> To --> " & oNumber,"")
Else
MessageBox.Show("Unable to convert : "& value, "")
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
- Highlight
- Email to a Friend
I really appreciate your work about this.
So, the answer is that 0.2 has been converted to 0,2!
Thank you so much! But now I'm not sure to understand which part of your code I must re-use in mine, and if y must do it everytime I need to enter a value (but I guess that yes, i must.)
- Highlight
- Email to a Friend
I couldn't work on a better response during work hours, but I did manage to make this code to give you an example of a way you could implement this. I will write something better tomorrow. Sorry
'Your Imports would be first.
Sub Main ()
'All of your main code would go here, right under the Sub Main()
Dim UserInput As String
UserInput = InputBox("Please Enter A Number", "ACME Number Machine", "")
If UserInput <> "" Then
oNumber = NumberMuncherUK(UserInput)
MessageBox.Show(oNumber,"")
Else
MessageBox.Show("Blank Entry","Error")
End Sub
Function NumberMuncherUK (IncString As String) As Decimal
Dim RetVal As Decimal
Dim UKculture As CultureInfo
'Dim FRculture As CultureInfo
'FRculture = CultureInfo.CreateSpecificCulture("fr-FR")
If Decimal.TryParse(IncString, style, UKculture, RetVal) = False
RetVal = -1.0
Return RetVal
End Function
Basically you would just call that function every time you wanted to see if the user input a correct value before passing it along. It returns a -1 (or whatever value you would like) so that you can use that in your logic down the road.
If UserInput = -1 Then
MessageBox.Show("You input a silly number!","")
So on and so forth.
- Highlight
- Email to a Friend
Okay, thanks a lot.
I'm not sure to fully understand so I tried to do use this like this:
Sub Main ()
Dim Module As String
Dim oModule As Decimal
Module = InputBox("Entrez le module du pignon:","NIHS 20-02","")
If Module <> "" Then
oModule = NumberMuncherUK(Module)
Dtete=oModule*(25+1.44)
Dprimitif=oModule*25
Dfond=oModule*(25-3.5)
Epaisseur_s=1.41*oModule
Rogive=0.8*1.44*oModule
Distance_t=Rogive-(Epaisseur_s/2)
End Sub
RetVal = -1.0
Return RetVal
End Function
But when it is compilating, it says that: "Value" isn't a member of "String".
- Highlight
- Email to a Friend
Actually, there are a few problems. You are using a dim called “Module” which is a reserved keyword in VB.net, and is the reason it turns up as a red color. I have rewritten your code, and it is working on my machine, but you will of course need to test it on yours. Notice how I also moved the calculations that are based on the user input to under the ‘If uModule <> "" Then’ ? That’s so that they don’t calculate using user input that hasn’t passed the condition check (the condition check in this case being the user input field being left empty or not).
Let’s see if the following will work correctly on your machine.
Sub Main ()
Dim uModule As String
uModule = InputBox("Entrez le module du pignon:","NIHS 20-02","")
oModule = NumberMuncherUK(uModule)
If oModule <> -1 Then
MessageBox.Show(DTete & " - " & Dprimitif & " - " & Dfond & " - " & Epaisseur_s & " - " & Rogive & " - " & Distance_t, "")
Else
MessageBox.Show("There has been a conversion problem from string to Decimal. Please Try Again.","")
Else
MessageBox.Show("You've left the input blank. Please start over.", "Blank Input Error")
End Sub
RetVal = -1.0
Return RetVal
End Function
I should also say that the only option in my ilogic editor that is checked is Silent Operation. I would suggest making sure you don’t have Straight VB code checked.
- Highlight
- Email to a Friend
So I try it at on my machine.
And I managed to make it work! Thank you!
I just need now to do it on every value! Thank you once again!
- Highlight
- Email to a Friend
That’s just great! In the spirit of uncovering more information about how this problem came about, I wanted to ask you a few questions. Which version of Inventor were you using before you had this localization problem? Was it localized in French, or was it an English language package? Was your computer set up with a different localization for the past / present Inventor installation, or has it always been set to French language?
If it seems that everything stayed the same, and only the Inventor version (from 2012 to 2013) made the difference, then they’ve changed how they calculate things based on the language culture, which would be righteous information to have if someone out there in developer land started to work on a plug-in / iLogic code that could potentially be used internationally.
Any who, thanks for your time! Continue to post in the customization forums if any other problems (or neat discoveries) arise.
- Highlight
- Email to a Friend
The version before was only Inventor 2012 in French. Nothings changed about it. I just have uninstalled the old one and install the new version. But if you remember, I have said that, checking on google, some people have the same issue, same error, with visual basic editors like iLogic on inventor, but on other software. So I'm wondering if it could be something with an update of windows 7 (I always had windows 7, but sometimes updates create some bugs here, I don't know).
I'm just wondering that in your code, you used "Style = NumberStyles.AllowDecimalPoint" . Don't you know if it's possible, at some point, to use this in the begining of the code to make it apply for every value next, automatically? Sorry, as I said, I'm not familiar with programmation, I'm learning by doing simple stuff.
- Highlight
- Email to a Friend
I’m glad that you asked. Yes there is a way to change the entire document’s culture info. The reason I didn’t go that route before was because I didn’t know if you had some users that were going to be using the ‘,’ decimal point and some that may use the ‘.’ point. With that being said, the following example will show you how to set up a main culture across your entire document, as well as some other information that you may find useful. If you have any other questions about this code, or anything else related, feel free to ask. This has been a real learning experience!
Imports System.Threading
Dim value, userInputString As String
Dim userInputDouble As Double
Dim InputBool As Boolean
'Thread.CurrentThread.CurrentCulture = New CultureInfo("fr-FR") ''' French language culture!
Thread.CurrentThread.CurrentCulture = New CultureInfo("en-GB") ''' English language (with a UK twist!)
'Thread.CurrentThread.CurrentCulture = New CultureInfo("en-US") ''' English language (with a Southern Twang!)
'Thread.CurrentThread.CurrentCulture = New CultureInfo("de-DE") ''' German language from the Father Land!
''' Here are some culture codes '''
''' en-GB - (English - Great Britain)
''' en-US - (English - United States)
''' fr-FR - (French - France)
''' de-DE - (German - Germany)
''' Simply replace the above 'New CultureInfo("??-??") with one of the codes to change
''' how this document reacts.
''' More culture codes can be found here :
''' http://msdn.microsoft.com/en-us/library/System.glo balization.cultureinfo(v=vs.71).aspx
''' In this comment section are some simple tests to see if your current culture is working
''' based on if the following value returns true or false.
''' Uncomment the code section you'd like to test with, if you'd like to test.
''' Only uncomment *one*. Specifically the one pertaining to the culture that you've set.
''' (Test for ENGLISH language culture. Should return true)
''' value = "0.2"
''' If IsNumeric(value) = True Then
''' Messagebox.Show("True","")
''' Else
''' MessageBox.Show("False","")
''' End If
''' (Test for NON-ENGLISH language culture. Should return true)
''' value = "0,2"
''' Else
''' End If
InputBool = False
While InputBool = False
userInputString = InputBox("Please Enter a Number. Your Current Culture is set to : " _
& Thread.CurrentThread.CurrentCulture.Name, "Title", "")
If IsNumeric(userInputString) = True Then
InputBool = True
userInputDouble = CDbl(userInputString)
Else
InputBool = False
MessageBox.Show("The number you entered - " & userInputString & _
" - was not recognized as valid. Please try again.","")
End While
MessageBox.Show("Your input, multiplied by 2 = " & userInputDouble * 2, "Result")
- Highlight
- Email to a Friend
I should note that there was a small error in my last code posts. I called out the culture info as “en-UK” when it should have been “en-GB” for English-Great Britain. Oops.
