• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customization
    Active Contributor
    Any ideas / advice why this macro does not work
    121 Views, 3 Replies
    10-03-2012 01:48 AM
    Hello All, any input would be much apprciated.
    The macro crashes on the second last line:
    "Call oSketch.DimensionConstraints.AddOffset(olines(1), oLine2, oDimCoords(1), False, False)"
    Here is the full macro code:
    Option Explicit
    Dim oDoc As PartDocument
    Dim oDef As PartComponentDefinition
    Dim oApp As Inventor.Application
    ' CONSTANT SIZES FOR MYLAR CREATION
    Const Mylar_X_Length = 80 'mm
    Const Mylar_Y_Length = 80 'mm
    Const Mylar_Thickness = 20 'mm
    Const Mylar_Width = 20 'mm
    Const Mylar_Fillet = 6 'mm
    Const Mylar_MCAllow = 3 'mm
    Public Sub L_Mylar()
    Dim oSketch As PlanarSketch
    Set oDoc = ThisApplication.Documents.Add(kPartDocumentObject, "Z:\TEMPLATES\INVENTOR\Sheet Metal (mm).ipt", True)
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    Dim oCoords(1 To 8) As Point2d
    Dim oDimCoords(1 To 5) As Point2d
    Dim oArc As SketchArc
    Dim oLine As SketchLine
    Dim olines(1 To 6)
    Dim oLine2 As SketchLine
    Set oDef = oDoc.ComponentDefinition
    Set oCoords(1) = oTransGeom.CreatePoint2d(0, 0)
    Set oCoords(2) = oTransGeom.CreatePoint2d(0, Mylar_Y_Length / 10)
    Set oCoords(3) = oTransGeom.CreatePoint2d(Mylar_X_Length / 10, Mylar_Y_Length / 10)
    Set oCoords(4) = oTransGeom.CreatePoint2d(Mylar_X_Length / 10, (Mylar_Y_Length - Mylar_Thickness) / 10)
    Set oCoords(5) = oTransGeom.CreatePoint2d((Mylar_Thickness + Mylar_Fillet) / 10, (Mylar_Y_Length - Mylar_Thickness) / 10)
    Set oCoords(6) = oTransGeom.CreatePoint2d((Mylar_Thickness + Mylar_Fillet) / 10, (Mylar_Y_Length - Mylar_Thickness - Mylar_Fillet) / 10)
    Set oCoords(7) = oTransGeom.CreatePoint2d((Mylar_Thickness) / 10, (Mylar_Y_Length - Mylar_Thickness - Mylar_Fillet) / 10)
    Set oCoords(8) = oTransGeom.CreatePoint2d((Mylar_Thickness) / 10, 0)
    Set oSketch = oDef.Sketches.Add(oDef.WorkPlanes.Item("XY Plane"))
    oSketch.Name = "SK_00 - PROFILE"
    oSketch.Edit
    Set olines(1) = oSketch.SketchLines.AddByTwoPoints(oCoords(1), oCoords(2))
    Set olines(2) = oSketch.SketchLines.AddByTwoPoints(olines(1).EndSketchPoint, oCoords(3))
    Set olines(3) = oSketch.SketchLines.AddByTwoPoints(olines(2).EndSketchPoint, oCoords(4))
    Set olines(4) = oSketch.SketchLines.AddByTwoPoints(olines(3).EndSketchPoint, oCoords(5))
    Set oArc = oSketch.SketchArcs.AddByCenterStartEndPoint(oCoords(6), olines(4).EndSketchPoint, oCoords(7))
    Set olines(5) = oSketch.SketchLines.AddByTwoPoints(oArc.EndSketchPoint, oCoords(8))
    Set olines(6) = oSketch.SketchLines.AddByTwoPoints(olines(5).EndSketchPoint, olines(1).StartSketchPoint)
    Call oSketch.GeometricConstraints.AddPerpendicular(olines(1), olines(2))
    Call oSketch.GeometricConstraints.AddParallel(olines(1), olines(3))
    Call oSketch.GeometricConstraints.AddParallel(olines(1), olines(5))
    Call oSketch.GeometricConstraints.AddParallel(olines(2), olines(4))
    Call oSketch.GeometricConstraints.AddParallel(olines(2), olines(6))
    Call oSketch.GeometricConstraints.AddTangent(olines(4), oArc)
    Call oSketch.GeometricConstraints.AddTangent(olines(5), oArc)
    Call oSketch.GeometricConstraints.AddGround(olines(1).StartSketchPoint)
    Call oSketch.GeometricConstraints.AddVertical(olines(1))
    Set oDimCoords(1) = oTransGeom.CreatePoint2d(-0.5, oCoords(2).Y / 2)
    Set oDimCoords(2) = oTransGeom.CreatePoint2d(oCoords(3).X / 2, oCoords(3).Y + 0.5)
    Set oDimCoords(3) = oTransGeom.CreatePoint2d(oCoords(3).X + 0.5, oCoords(3).Y - (Mylar_Thickness / 2) / 10)
    Set oDimCoords(4) = oTransGeom.CreatePoint2d(Mylar_Thickness / 10 + 0.5, oCoords(3).Y - (Mylar_Thickness / 2) / 10 - 0.5)
    Set oDimCoords(5) = oTransGeom.CreatePoint2d((Mylar_Thickness / 2) / 10, -0.5)
    Call oSketch.DimensionConstraints.AddOffset(olines(6), olines(2), oDimCoords(1), False, False)
    Call oSketch.DimensionConstraints.AddOffset(olines(1), olines(3), oDimCoords(2), False, False)
    Call oSketch.DimensionConstraints.AddOffset(olines(2), olines(4), oDimCoords(3), False, False)
    Call oSketch.DimensionConstraints.AddRadius(oArc, oDimCoords(4), False)
    Call oSketch.DimensionConstraints.AddOffset(olines(1), olines(5), oDimCoords(5), False, False)
    Dim oCollection As ObjectCollection
    Set oCollection = ThisApplication.TransientObjects.CreateObjectCollection
    oCollection.Add olines(1)
    oCollection.Add olines(2)
    oCollection.Add olines(3)
    oCollection.Add olines(4)
    oCollection.Add oArc
    oCollection.Add olines(5)
    oCollection.Add olines(6)
    Call oSketch.OffsetSketchEntitiesUsingDistance(oCollection, Mylar_MCAllow / 10, False, False, True)
    Set oLine2 = oCollection.Item(1)
    oSketch.ExitEdit
    End Sub
    Regards
    Rob
    Windows 7 Pro (X64)
    Intel(R) core (TM) i7-2600 CPU @ 3.40GHz
    16.0 GB RAM
    Nvidia Quadro 600
    Autodesk Inventor 2013 Professional Ultimate Design Suite
    Please use plain text.
    Valued Contributor
    jonbrabbs
    Re: Any ideas / advice why this macro does not work
    10-04-2012 06:01 AM in reply to: rvangend
    Hi Rob,
    I can help a little. oLine2 = oCollection.Item(1), is refering the your original set of lines, not the offset ones. Therefore you're trying to add a dimension from oLines(1) to oLines(1).
    I'm afraid I haven't got any spare time at the moment to look at this further. Hope this gives you a starting point at least.
    Kind regards
    Jon.
    If this post helps you, please give kudos.
    Active Contributor
    10-04-2012 07:14 AM in reply to: rvangend
    Hello Jon,
    I realised that after I posted and should probably have deleted the post.
    But, Is there any way to iterate the offset group and find the line that matches olines(1) (or oline(2) and so on)  so that I can add a dimension?
    Thanks for you input.
    Regards
    Rob
    Regards
    Rob
    Windows 7 Pro (X64)
    16.0 GB RAM
    Nvidia Quadro 600
    ADN Support Specialist
    xiaodong.liang
    10-17-2012 07:23 PM in reply to: rvangend
    When you said 'offset group', did you meant by 'oCollection' in the code? A collection can be iterated like below:
    Dim oEachObj as Object
    For Each oEachObj in oCollection
    Next
    If I misunderstood, please feel free to elaborate your question
    Xiaodong Liang
    Developer Technical Services
    Autodesk Developer Network
