Alternative materials
Hi
Anyone know where to find/import alternative materialstyles
egg. AISI 301? EN 1,4310?
Working whit sheet metal parts an missing a lot of materials.
I know how change the existing materials, but would rather import them from the web.
Regards
Rasmus
xiaodong_liang
Autodesk Support
Autodesk Support
I am not much clear what you wanted to do. What I know is: you can add a new material by Materials.Add and the material can set the RenderStyle which could configure some parameters from the params of the source material.
I'm looking to import materials. I do not know from where( fx. Supplyer)and if it's possible? Venlig hilsen/ Best Regard Rasmus Danielsen AH Metal Solutions A/S
xiaodong_liang
Autodesk Support
Autodesk Support
Sorry, I am not still not clear what you meant by "Import Material".
In UI, you can create material, open existing library. Did you meant the equivalent ability of API?
Yes. The same as API. An also if some metalsupplyers can supply the data for import. Venlig hilsen/ Best Regard Rasmus Danielsen AH Metal Solutions A/S
tuliobarata
I guess its the same what I'm looking for, some pre defined materials with the right properties values of it standard, like AISI 304, ASTM A-36, ANSI XX, etc....
here I didnt find any site with files to import, so I had to create one by one, at least the more usuals here...
IV 2013
xiaodong_liang
Autodesk Support
Autodesk Support
What I can see is: you have to add the materials youself with the current API. I did not see a way to import a material. Sorry.
