Add a column to a partslist
I need to add a custom column to a parts list
and have it display as the last column.
oPartsList.PartsListColumns.Add (kCustomProperty)
This code runs, but nothing happens...no error...no column...
Any suggestions?
Victor
SonnyN
Archived Account
Hi Victor,
As per online help it requires PropID arg when you use kCustomProp.
Try something similar to the following code:
Sub AddCustomProperty()
' Assuming the current active document is Drawing
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrawDoc.ActiveSheet
' Assuming there is at least one partslist on the activesheet
Dim oPL As PartsList
Set oPL = oSheet.PartsLists(1)
' Create a custom PropertySet & Property
Dim oPropSet As PropertySet
Set oPropSet = oDrawDoc.PropertySets.Add("Custom BOM Props")
Dim oProp As Property, vPropVal As Variant
Set oProp = oPropSet.Add("Yes", "Purchased")
' Create the custom column
Dim oPLCol As PartsListColumn
Set oPLCol = oPL.PartsListColumns.Add(kCustomProperty, , oProp.PropId)
oPLCol.Title = "Purchased"
End Sub
Thanks.
-Sonny N
(Autodesk)
Your sample allows me to add custom properties to a parts list. I need 3 additional columns & the related parameter values (dimensions that I defined in each of my parts). Using your code, I can add the 3 extra columns I need, but can't figure out how to assign the parameter values I need (and have stored for the parts) to them.
*** Code below ***
oPropSet = oDrawDoc.PropertySets.Add("plist_columns")
Dim oProp1 As Inventor.Property
Dim oProp2 As Inventor.Property
Dim oProp3 As Inventor.Property
Dim vPropVal As Object
oProp1 = oPropSet.Add("", "Length1")
oProp2 = oPropSet.Add("", "Width1")
oProp3 = oPropSet.Add("", "Thickness1")
oPLCol = oPL.PartsListColumns.Add(PropertyTypeEnum.kCustomProperty, , oProp1.PropId)
oPLCol.Title = "Length1"
oPLCol = oPL.PartsListColumns.Add(PropertyTypeEnum.kCustomProperty, , oProp2.PropId)
oPLCol.Title = "Width1"
oPLCol = oPL.PartsListColumns.Add(PropertyTypeEnum.kCustomProperty, , oProp3.PropId)
oPLCol.Title = "Thickness1"
I know it's an old thread, but have you then solved the problem on how to add a new custom property and read the properties values?
xiaodong_liang
Autodesk Support
Autodesk Support
Hi dbrizio,
I think the PartsListColumns.Add is still the method to add column of custom property. Did you meet any specific problem? Could you provide a demo code?
