API path to iproperties values
john
john
I'm trying to write a macro that needs a path to read/write to the iproperties within a .ipt file. For instance I want to be able to change the Title, the keywords, and the vendor of a .ipt file using visual basic code. I tried using ThisApplication.ActiveDocument.PropertySets.Item.Item.Value and other variations, but cannot seem to find a valid path. If you have knowledge of this could you also provide a sample of code?
The online help has a good example of how to access properties.
One example would be
oPropsets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(kEngin
eerDesignTrackingProperties).Value = "Stuff"
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"pharmer123" wrote in message
news:f1848f9.-1@WebX.maYIadrTaRb...
Have a look in Inventor Customer files, named
"Inventor/VB(A)/Class to handle Document Properties"
Anton
Anton! How have you been?
Sean Dotson, PE
"avbuiten" wrote in message
news:f1848f9.1@WebX.maYIadrTaRb...
> Anton
Bad, but the head above see level again.
Enjoying solving Inventor/VB(A) problems.
Happy seeing you still (very) active in these groups.
Partly working on EDM/AutoCAD projects, and in due time EDM/Inventor projects.
Greetings,
Anton
Sounds interesting. Let me know about the EDM- Inventor. We currently EDM
our parts from AutoCAD.
Sean Dotson, PE
news:f1848f9.3@WebX.maYIadrTaRb...
projects.
> Greetings,
> Anton
Hi Sean,
Well i am still learning the howto, but more important the why? It's a complete different material and it take me a while to think like a designer for it's need to store and retrieve their documents, the relations between drawings and other documents, many different procedures for workflow etc. Which EDM system do you use? (if i may ask)
Anton
