• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customer Files
    New Member
    Inventor > Autodesk FBX
    1702 Views, 3 Replies
    05-05-2010 08:30 AM
    I need an Inventor file converted to FBX format.
    I've been using 3DS Max to import an IAM assembly but I've found that there are numerous errors with materials. Such as some colours being imported consistently wrong, and some objects being painted with a single material when it should have several.
    For example, some pipes in my Inventor file are green. However, every time I import them into 3DS they turn bright orange. And some signs have text extruded from them which should appear white against a coloured background, but the text just takes on the colour of the background.
    I also have a problem with entire parts dissapearing for no reason, this could be something to do with translucency? They're not just transparent in 3DS because I can't find them in the browser.
    I've ticked the import inventor materials and material IDs options so they're not the problem. Is there any way around these colour issues? Do I need an update or new plugin?
    I'm using 3DS Max 2009 and Inventor 2009.
    Jamie.
    Please use plain text.
    *Dennis Jeffrey
    Re: Inventor > Autodesk FBX
    05-05-2010 09:54 AM in reply to: JamieEclipse
    Wrong Discussion group. Inventor questions shpould be posted here:
    http://discussion.autodesk.com/forums/forum.jspa?forumID=78
    However, I'll answer the question. Inventor ( even 2011) does not
    support the FBX format.
    Dennis Jeffrey, Autodesk Inventor Certified Expert
    Subscribe to the free "The Creative Inventor Magazine now available at:
    http://teknigroup.com/CI-Subscribe-Login.asp
    New Member
    05-06-2010 04:18 AM in reply to: JamieEclipse
    Did you actually read my post?
    Inventor > 3DS > FBX
    *Dennis Jeffrey
    05-07-2010 10:26 AM in reply to: JamieEclipse
    Yes I did. Repost your question in the discussion group link I provided.
    However, you will probably get more help in the 3D Studio discussion
    group. You will probably need to zip and attach all files in the proper
    group. This group is rarely accessed.
