• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customer Files
    Member
    INV2010 Mass property error
    364 Views, 0 Replies
    09-09-2010 03:12 AM
    Hope someone can help with this error.
    I run 2 seats of INV2010 Pro with SP3 installed and 4 seats of INV2010 Series with SP1-Sp3 installed.
    I have a concave disc with cuts to the outer periphery (Blade - Notched Error.ipt) which when saving the .ipt file creates an error box which says "Mass Property calculations could not match requested accuracy".
    If the pattern of cuts is reduced from 10 to 7 the error stops (Blade - Notched Error.ipt). If 8 is the pattern quantity then the error returns.
    The file (Blade - Notched Base.ipt) was created in Solidedge and sent to me by a 3rd pary as a .stp file. This has the same error on save as Blade - Notched Error.ipt.
    This may seem to be a small error, but when a large assembly with any of the 2 error parts either placed or patterned is saved the error repeats for every instance that the error part is included.
    This has only started occuring since installing SP3 to INV2010 Pro on my workstation and a laptop but does not occur on the other 4 seats with INV2010 Series Sp1-Sp3 installed.
    Any thoughts.
    Adrian Hartley
    Simba International
    Please use plain text.
