• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customer Files
    Member
    Help With a Simulation
    129 Views, 1 Replies
    12-27-2009 12:26 PM
    I never worked with Inventor Simulation before and am having trouble running a simple Simulation. Hoping for some help from this group?
    The attached ZIP contains the necessary files for the simulation. I am tyring to determine the upward force imposed on the blue lift block by this mechanism throughout the range between hard stops when driven by a 63mm bore cylinder (20mm rod dia) at 4bar (about 1112N). I can then do "what ifs" with differents cylinder sizes.
    It seems to be working but I don't know how to get the force I'm looking to the output graph?
    Any help would be greatly appreciated
    Rick
    Please use plain text.
    Employee
    Re: Help With a Simulation
    01-03-2010 10:16 PM in reply to: rdonnellon
    Hi Rick,
    You can calculate the value of upward force on lift block with "unknown force" functionality. Before invoking this command, please disable the imposed motion for cylindrical:2 joint and lock revolution degree of freedom for planar joint:9 since there are 2 degrees of freedom for this mechanism but "unknown force" only works under kinematic chains with one degree of mobility.
    Then you should specify the joint you want to dive to have a succession of static equilibriums and its final position, like the translational degree of freedom of cylindrical joint 2.
    If you still have problem to finish this, please feel free to let me know.
    -Jimmy Yuan
    Jimmy Yuan
    Software Quality Assurance Engineer
    Inventor Simulation
