• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Customer Files
    Active Contributor
    Convert 3D DXF to Inventor
    1746 Views, 1 Replies
    09-21-2010 07:47 AM
    I have a dxf file (3D) that want to esport to a inventor model.
    I have tried to export as a IGES and STEP but they only do complex surfaces and Inventor crashes...
    It is possible to export as a solid???
    Do I have to use another way??? (save as a DWG...)
    Open the dwg in inventor doesn't work because all is in model space and then I do not know what to do.
    Open in a sketch???
    Can anyone help me?
    Please use plain text.
    New Member
    SKARLEZ
    Re: Convert 3D DXF to Inventor
    10-26-2010 10:22 PM in reply to: UserEMC
    Hello, i 'll try to be useful to your problem
    So, first of all lets open autocad  and your .dxf there is a command (sorry i don't remember it but you will find it in a book of autocad) that you could present your 3d model to the 3 basic views.
    After that you could import your 3 views .dwg and with the following link video you will have your result!!!
    http://inthemachine-autodesk.typepad.com/blog/2010/07/index.html
