• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Infrastructure Modeler
    Member
    schmidtj
    Issues with import from IMX Export
    106 Views, 3 Replies
    02-10-2012 08:38 AM
    Civil 3D Surface elevation is ~2000. When that surface is import into AIM it's elevation is ~6000. Seems like a meters/feet issue but can't see where. AIM is set to measure in feet. Both AIM model & Civil 3D source drawing are assigned to NV83-EF. Any ideas?
    Employee
    eric.fain
    Re: Issues with import from IMX Export
    02-10-2012 10:54 AM in reply to: schmidtj
    Hi. Thank you for posting. This is a known issue. There is a workaround, which is to scale the Z value on import by
    0.3048. Can you try that and see if that solves the problem?
    Member
    schmidtj
    02-10-2012 10:55 AM in reply to: schmidtj
    The landxml import of save surface seems to do the same thing. If reimported into civil 3d its at the right elevation.
    Active Contributor
    02-10-2012 12:37 PM in reply to: eric.fain
    Is this a m/ft thing!
    My seperate export into 3ds Max suffer from some serious mis alignment!
    I want everything perfect with FBX export, and notice small things, it might be same.
    No problem!m I prefer to do it all in one file, and possible, but for laptops, etc this is not an option.
    I got ssd/ram that IM love!, if money but it, IM only 5000$, my boss got it for free on top of it, but not the map/real deal he he.
    Is IM gonna deliver cloud GE service, integrated with Civil3d, map3d, Revit, ahh, I got dreams for IM.
