• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk InfraWorks
    Valued Mentor
    water areas within designed dams and channels
    455 Views, 2 Replies
    02-19-2013 02:34 AM
    AIM 2013
    How do you present designed dams and water channels in AIM?
    In my first attempt I am only dealing with dams.
    The dams have been designed in C3D using C3D grading.
    I opted not to use IMX to represent the damns as I wanted to make a clear difference between the Terrain and the dam regions.
    Instead, I used FBX. Imported into AIM as Buildings.
    I think this is already wrong as AIM seems to avoid buidlings when creating water areas manually.
    What AIM object do I use to represent dams and channels - needing to contain water areas?
    Thx,
    Kevin.
    Please use plain text.
    Valued Mentor
    Re: water areas within designed dams and channels
    02-19-2013 03:08 AM in reply to: kevin.barnett
    oops ... it was the holes in the NGL surface that caused the 'non-water' problem.. I made holes where the dams are..
    now I filled in the holes and the water is working correctly .. even with the dams represented as buildings..
    almost there ..
    Valued Mentor
    02-19-2013 04:29 AM in reply to: kevin.barnett
    the solution is to make deep holes in the terrain source data, way deeper than the designed surface..
    : ) I now have instant cool water waves - thank you Autodesk : )
