• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk InfraWorks
    New Member
    slezacek
    WMS Server
    219 Views, 3 Replies
    04-16-2012 12:50 AM
    Hello, I would like  conect to WMS from IM. Is it possible ?
    Thank you. Filip
    Please use plain text.
    Employee
    konstantin.baumann
    Re: WMS Server
    04-16-2012 01:46 AM in reply to: slezacek
    Since we are using GDAL (1.8.x) for raster data input, this page might help you to setup the required XML description file for describing the corresponding WMS server: http://www.gdal.org/frmt_wms.html
    If you need more support you could also post some more infos about the WMS you want to access and we can try to figure out, which paramaters to set in the required GDAL-XML file...
    New Member
    slezacek
    Re: WMS Server
    04-17-2012 02:28 AM in reply to: konstantin.baumann
    Hello Konstantin,
    thank you for your answer. Can you help me with this url ? : http://wms.cuzk.cz/wms.asp
    Thank you. Filip
    Employee
    konstantin.baumann
    Re: WMS Server
    04-17-2012 05:41 AM in reply to: slezacek
    Since the call to:
    http://services.cuzk.cz/wms/wms.asp?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
    does not return a XML specification of this service, I don't know how to get to the required elements for the GDAL XML file.
    This sample request demonstrates an expected and usable XML server reply:
    http://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
    Maybe you can check for the bbox of the service in LL84 and also figure out the ground pixel resolution of the highest resolution layer?
