• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk InfraWorks
    Valued Contributor
    Text
    131 Views, 3 Replies
    04-18-2012 04:31 AM
    Does anyone know of a way to add a frame of text to the begining of "movie"?  I wanted to add a disclaimer but when I add it through a thrid party I seem to loose a lot of resolution.
    Ideas?
    Thanks!
    Please use plain text.
    Employee
    konstantin.baumann
    Re: Text
    04-23-2012 03:05 AM in reply to: kolk
    Which programs did you try so far?
    I haven't done video editing myself yet so far but would expect that every video editing tool should provide such a functionality?
    DarrenP
    Re: Text
    04-23-2012 08:58 AM in reply to: konstantin.baumann
    yes that is correct
    also exporting the movie out of those programs will be different also because there is so much more setting in those programs
    Employee
    Re: Text
    04-24-2012 01:47 AM in reply to: kolk
    Hello!
    I guess by "loosing resolution" you mean a degrading video quality. The easiest solution would be to export uncompressed video from AIM and do the compression only with your video editing tool. But be warned: uncompressed video requires a lot of storage. If you are actually loosing pixels please check the video frame settings in your tool. Usually, such tools use certain presets with fixed resolution (e.g., PAL, NTSC, DV, FullHD) and scale your content to this resolution. For a more specific answer I need to know your tool.
    Haik.
