• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk InfraWorks
    Storyboards and Proposals
    265 Views, 7 Replies
    01-02-2013 10:05 AM
    Im still in the learning process, however I am trying to figure out how to show different proposals with storyboards.  On the ipad you can view storyboards and layers, if i could assign proposals to storyboards that would be ideal.  Any thoughts?
    Please use plain text.
    *Expert Elite*
    TRogers
    Re: Storyboards and Proposals
    01-02-2013 11:03 AM in reply to: mshoffman
    That can be done by creating different Scenarios.  Under the Present tab, it's the first button.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    01-02-2013 11:05 AM in reply to: TRogers
    I can create a scenario, however where do you specify which proposal you want to use in the scenario?
    *Expert Elite*
    TRogers
    01-02-2013 11:10 AM in reply to: mshoffman
    Good question.  I see where you can link it to the Storyboard.  Konstantin (Autodesk), any suggestions?
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Employee
    eric.fain
    01-02-2013 11:16 AM in reply to: mshoffman
    When you are publishing a Scenario, the active Proposal is used to create it. There is no direct link to the Proposal from the Scenario itself. If you need to tie together a Proposal and a Scenario use a naming convention to do this.
    *Expert Elite*
    TRogers
    01-02-2013 11:17 AM in reply to: eric.fain
    Wish list?
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    01-02-2013 11:18 AM in reply to: TRogers
    I concur.  Having some checkboxes to include proposals like you can with storyboards when publishing would be nice.
    01-02-2013 12:07 PM in reply to: mshoffman
    On second thought, Having to publish multiple scenarios to see different proposals is a lot considering each scenario is a separate file on the ipad's application.  What would be better is to be able to specify the proposal you want to see on the story board.
