Autodesk InfraWorks
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Sketchup Warehouse to AIM
- Highlight
- Email to a Friend
So, I followed the steps HERE to bring in sketchup buildings into myAIM model but the problem I'm having is the image that is a part of the sketchup file is coming in as well. If I go into 3DS Max and remove the image, the fbx file still has the image and I'm not sure how to get rid of it. Any ideas?
Re: Sketchup Warehouse to AIM
- Highlight
- Email to a Friend
Aha! I figured it out! All by myself! And I'm not telling!
Ok, I'll tell. What I did was to erase the image out of 3DS Max Design, and then, instead of using the Export command, I selected the objects in the model and chose Export Selected. Worked BEAUTIFULLY! http://screencast.com/t/sEQZq5Kl
- Highlight
- Email to a Friend
If there were a AIM wishes page, I'd add a wish to import a SKP directly.
- Highlight
- Email to a Friend
Fortunately, most people that will be using AIM have the Infrastructure Design Suite so they have 3DS Max as well. There is a plug in available in the AutoCAD Exchange that will import a Sketchup file directly into AutoCAD but I was having odd results with that. The 3DS Max route seems to work best for me.
- Highlight
- Email to a Friend
And you should be able to "send-to your current 3D model" from 3ds max directly to AIM:
- open your AIM model you want the 3d model imported into
- select the 3D model in 3ds max you want to send-to AIM
- select the 3ds max application icon at the top left and then select "send-to AIM"...
- the model should then appear "magically" in AIM, where you can configure it and place it interactively
- Highlight
- Email to a Friend
That worked really slick. I'll have to try it again with the file with the image and see if I have the same issues (I'm assuming I will because it probably just automates the export everything to fbx command).
