• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk InfraWorks
    Valued Contributor
    YRogachev
    Accepted Solution
    Invisible edge
    474 Views, 5 Replies
    12-19-2012 04:03 AM
    Why some edges of these buildings are invisible? They was made from shp file, AIM 2013R2. And I have a lot of same buildings with invisible edges in the model.
    _____________________________________________________________
    Мой опыт внедрения Civil 3D
    yrogachev.blogspot.com
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: Invisible edge
    12-19-2012 05:48 AM in reply to: YRogachev
    Try THIS, on the View tab of the ribbon, toggle on "Show Backfaces"
    Valued Contributor
    YRogachev
    Re: Invisible edge
    12-19-2012 07:07 AM in reply to: YRogachev
    Thank you!
    It's works!)
    Distinguished Contributor
    Re: Invisible edge
    05-06-2013 11:02 AM in reply to: YRogachev
    Just saw this, this is so important, it should be checked by default!
    I was about ready to model a bunch of houses individually in sketchup and bring in as city furniture method instead of extruded footprints.
    SOOO glad you guys solved this and posted on it.
    *Expert Elite*
    Re: Invisible edge
    05-06-2013 01:09 PM in reply to: jmaeding
    The higher the data amout the higher the performance needed on GPU(s) to render faces. To automatically set this options means that every face is rendered from both sides (internally) which might result in performance conflicts.
    The switch is necessary when getting/importing geometry that has not oriented the face-normals to the same side (knowing what is inside, what is outside for faces/surfaces), so yes, it has to be activated on some needs, but not as default.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Re: Invisible edge
    05-06-2013 01:48 PM in reply to: alfred.neswadba
    in that case, AIM has a bug.
    Those faces were generated from extruded shapes by AIM.
    If it cannot orient the faces outside, which there clearly is an outside to a polygon, its not working.
