• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk InfraWorks
    Member
    Ground Imagery Over Exposed
    421 Views, 2 Replies
    10-02-2012 06:31 AM
    I have been experiencing this problem for quite some time and I cannot seem to find a way to resolve it. Hopefully someone will have a suggestion. When I import Ground Imagery, the contrast is often way too intense as if the image is over exposed or a contrast and brightness filter were applied improperly. I checked the image in Photoshop and the brightest areas are well below 255.255.255 RGB white. I would almost say that some shader is parcing the images wrong for the viewport. Has anyone else experienced this issue? Anyone found a way around it?</
    Mark Kauffman
    Project Visualization
    Parsons Brinckerhoff, Inc.
    Please use plain text.
    *Expert Elite*
    TRogers
    Re: Ground Imagery Over Exposed
    10-02-2012 09:05 AM in reply to: kauffman
    See my post at the link below and see if that helps....
    http://forums.autodesk.com/t5/Autodesk-Infrastructure-Modeler/Odd-Image-Display/td-p/3604230
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Member
    10-02-2012 09:22 AM in reply to: TRogers
    That's a negative. The image only appears to have the 3 color channels and not a 4th. My imagery is defaulting to a band mapping type of RGB. As a test to see what would happen, I switched to Gray and set band #1: red as the type. I get a grayscale image for the aerial as expected, but the white are completely blow out as before. Again, it is as if AIM is applying a contrast and brightness filter to the image.
    Mark Kauffman
