• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk InfraWorks
    Distinguished Contributor
    Accepted Solution
    Can AIM model curvature of the earth?
    678 Views, 9 Replies
    09-18-2012 04:08 PM
    I know it uses a tin surface, which cannot wrap under itself, but if I choose a coordinate system like UTM 11, will it drape that surface around a globe? (like google earth)
    any suggestions on tools that can do that besides google earth?
    I have arcscene and manifold gis progs, just never cared about the effects of earth curvature on what  given viewpoint can see.
    Please use plain text.
    spatialguru
    Re: Can AIM model curvature of the earth?
    09-18-2012 08:56 PM in reply to: jmaeding
    The two that come to mind are ossimPlanet and WorldWind (though I don't know WW really much at all).  ossimPlanet is totally built on a global model and can do some great stuff.  You'll probably want to extend it further for your particular solution but it might be more inspiring than google earth at this point.
    Enjoy!
    http://trac.osgeo.org/ossim/wiki/OssimPlanet
    http://download.osgeo.org/ossim/installers/
    Geo-geek, Publisher, Author
    http://LocatePress.com
    http://WebMappingIllustrated.com
    http://actian.com/products/ingres/geospatial
    Employee
    konstantin.baumann
    09-19-2012 07:59 AM in reply to: spatialguru
    Yes, AIM supports the earth curvature automatically...
    09-19-2012 09:07 AM in reply to: konstantin.baumann
    what do you mean by support though? Does it always use a "foundation" of a globe?
    I would think it depends on the models coordinate system, projected or a non-projected system.
    Another interesting issue is atmospheric diffraction, which I heard usually takes away about 1/2 the effect of curved earth.
    So you see over the horizon a bit as light follows the earth. Now that would be an impressive model!
    Employee
    konstantin.baumann
    09-19-2012 09:14 AM in reply to: jmaeding
    AIM requires you to correctly geo-reference your model and based on that can support the earth curvature automatically for all projects... just make them large enough and you will see...
    About the atmospheric diffraction you mentioned: I would not expect that in the very near future... :-)
    09-19-2012 11:38 AM in reply to: jmaeding
    I will try using UTM or something
    spatialguru
    09-19-2012 11:57 AM in reply to: jmaeding
    Totally off topic from AIM, but I forgot to mention, depending on capabilities you need or real-time spatial dynamics, you might also be interested in http://cesium.agi.com/
    Employee
    09-20-2012 03:08 AM in reply to: jmaeding
    Hello
    If you choose an UTM zone you will restrict your model extend to the valid extend of that specific UTM zone. To work in a world context, it is best to use a worldwide valid coordinate system (CS). Therefore I would recommend not to change the database CS as LL84 is worldwide valid.
    You will not gain anything by changing the database CS and you can still change the display of the coordinates any time by modifying the User Coordinate System.
    Heiko
    Heiko Meyerdirks
    Engineering Manager
    Autodesk IPG ICP InfraWorks
    09-20-2012 08:31 AM in reply to: jmaeding
    ah, thanks for the tip.
    I tend to use CA state plane zone 6 prettymuch all the time, so am less educated on the "global" coordinate systems other than figuring out which one is used by a given chunk of data.
    *Expert Elite*
    BrianHailey
    09-24-2012 06:15 PM in reply to: jmaeding
    Here's an example of AIM showing curvature of the earth:
    http://screencast.com/t/xqXvIZxULN
