• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk InfraWorks
    Employee
    Re: Autodesk Infrastructure Modeler error
    08-02-2012 02:53 AM in reply to: Metsihafe_M
    Hello Peter
    I am sorry to hear this. We reopend the corresponding defect and will try to find out by what other product this can also be caused.
    Heiko Meyerdirks
    Engineering Manager
    Autodesk IPG ICP InfraWorks
    Please use plain text.
    Member
    08-02-2012 06:18 AM in reply to: heiko.meyerdirks
    It is solved for me. Except my adobe is giving some warning.
    Metsihafe M
    Metsihafe M
    Employee
    08-02-2012 07:39 AM in reply to: peterwitjes7473
    Hi Peter,
    Can you do a thorough search of your hard drive and registry for both acaptuser64.dll and acaptuser32.dll, to make sure some other product did not install any version of those? It's worth double checking this because it has solved the problem for all other people that we know of with this problem.
    Traian
    Active Member
    peterwitjes7473
    08-03-2012 12:35 AM in reply to: heiko.meyerdirks
    Hi Traian,
    I've just twice checked everything. The registry and hard drive gives no result for acaptuser32.dll and acaptuser64.dll.
    In the registry I also looked at the CheckedValue key in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL was set 1 to ensure that all folders are shown. After that I checked the registry and hard drive again, but no results.
    Sorry, but no results
    regards,
    Peter
    Valued Contributor
    09-11-2012 01:26 PM in reply to: peterwitjes7473
    Remove the 64bit addon worked for me too. Thanks
    Active Member
    peterwitjes7473
    09-17-2012 02:00 AM in reply to: PatrickManson
    Finally .... it works. The problem is the Windows 7 version. I bought a new W7 pro version and installed everything again, and it works.
    In an earlier state I installed the pre-installed W7 home premium version and the problem resist. So, after all the other solutions that I tried the last option for me was to buy a new windows 7 pro version.
