• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk InfraWorks
    Valued Contributor
    YRogachev
    Attributes display settings
    388 Views, 7 Replies
    02-07-2013 11:27 PM
    I have DWG drawing with map of city. This map consist of polygons of buildings with different attributes, like numbers of floors, address, type of material, type of property and etc.
    I exported this data through SDF format with attributes to AIM. There are no problems, all data imported correct and attributes imported like Properties of text and Properties of numbers.
    My questions:
    1. How I can extract this attributes to tooltip or something, which can show all data attributes in building?
    2. How I can chose all buildings, who, has number of floors less than 1? I think I have to use Select by Filter but I can’t compose right expression.
    3. I have in attributes (Properties of text) type of building material (Brick, wood, stone and etc.). How I can compose expression in style by rule that all brick buildings has special style and all stone buildings another style?
    _____________________________________________________________
    Мой опыт внедрения Civil 3D
    yrogachev.blogspot.com
    Please use plain text.
    Active Contributor
    cpennetti
    Re: Attributes display settings
    04-02-2013 11:07 AM in reply to: YRogachev
    I'd like to know this as well.  Is it possible to select a geometric attribute, and assign a style.  For instance, grab every building smaller than 5,000 SF footprint, and assign a house style?  I know i can theme items, or select by filter and then style, but if i have to re-import i lost those settings.
    Am I missing something, where you can style by ranges, similar to Map 3D?  Or should it all be themes?  I'm really liking the 2014 trial that's out... moving clouds, new design tools, better lighting, very cool
    Employee
    04-03-2013 06:38 AM in reply to: YRogachev
    You may create a rule for it (Style Rules) which get stored with the model and can be applied all as often as you like. You still can do manual changes to the stylization which will override the rule style using the manual style field. Just make sure you do not set a default manual style during import, otherwise all rule styles get overwritten for every asset.
    Heiko Meyerdirks
    Engineering Manager
    Autodesk IPG ICP InfraWorks
    Active Contributor
    cpennetti
    04-03-2013 06:55 AM in reply to: YRogachev
    Thank you for the reply.  Would you be able to post a quick expression that would help us out with something like this?  Something that would set a style/color/roof slope based on an attribute of the data, or maybe a geometric calculation?
    Some of the examples included in the software really help, related to creating multi-line descriptions, or the new features with adding that data directly to the tool tip on inmport really help.  So maybe just something similar, or if you could point to a blog or help page that already has it, that would be good.
    A lot of the data comes in as boolean, even if it's originally double, which makes it tough to grab a range of values.  The footprint is a good example.  I can create a field that adds that data automatically, but I'm not sure how i'd map it in InfraWorks that would allow me to style all buildings from 0-3,000 SF, and then 3,000 - 10,000 SF, etc.
    Employee
    04-03-2013 07:29 AM in reply to: YRogachev
    Looking at you example, InfraWorks has some limitations. You can only use the attributes you map during import. There is currently no way to bring in and work with additional attributes. Below you will see an example how this can be done regarding the floors example.
    Unfortunately there are no geometry calculations available. But you have for example interactive spatial tools. You will find the editor for the expression by clicking the edit button in the rule editor:
    Heiko Meyerdirks
    Engineering Manager
    Active Contributor
    cpennetti
    04-03-2013 07:34 AM in reply to: heiko.meyerdirks
    I see, well that's a big help.  But you're saying then that with current InfraWorks, if I wanted to look at another attribute, like number of cars that travel along a road, that isn't mapped to an InfraWorks geometric component (like number of lanes) there's no way to set a style rule?
    Employee
    04-03-2013 07:58 AM in reply to: YRogachev
    That is correct. However, there is one advanced option, here is a blog post:
    If you plan to take advantage of it, I recommend you create a copy of your model first thing, as modifying the schema can lead to a corrupted model.
    Heiko Meyerdirks
    Engineering Manager
    Active Contributor
    cpennetti
    04-17-2013 06:15 AM in reply to: heiko.meyerdirks
    Just wanted to say the replies were very helpful, I'm back into it all and moving a lot faster with these tips.  The facade creation is still a little challenging to use, but the ability to code in styles is a big help.  Thanks Heiko
